High Beam issue on 1978
Old Apr 14, 2007 | 05:56 PM
I1R9O8C6Z's Avatar
I1R9O8C6Z
Default High Beam issue on 1978
While driving a 78 PACE car that I recently acquired. I found that when the lights are on high beam the headlights go completely out occasioanlly, like a loose ground or something. I returned to low beams and they work fine. Any suggestions before I dive into this issue and try to correct the problem?
Old Apr 14, 2007 | 06:29 PM
SIXFOOTER's Avatar
SIXFOOTER
Ground is common between the high and low beams, if the low beam works good its not ground. Could be a flakey high/low switch or a flakey breaker. Of course everything from the switch to the hedlights could do it too.
Old Apr 14, 2007 | 07:02 PM
shafrs3's Avatar
shafrs3
My Hi Lo floor switch gave me this symptom on my '72.
Old Apr 16, 2007 | 07:36 PM
I1R9O8C6Z's Avatar
I1R9O8C6Z
Thanks for the responses
To High Beam issue on 1978
