Adjusting Lifters
Old Apr 14, 2007 | 08:52 PM
80TexasC3's Avatar
80TexasC3
"Rodstoration &am p;quot; In Progres
Default Adjusting Lifters
Can I get some advice on if I should adjust my lifters...and if so... what is a good process for doing this....
I've had a lifter that has always been a little loud...and the others aren't really all that quite. Was told by the engine shop that this is partially due to the aggressive cam grind (XE274 Roller).
Thanks in advance...If I can quite them down and it would be good for the engine then I would like to take care of this.
Ed
Old Apr 14, 2007 | 09:10 PM
Godfathers Ghost's Avatar
Godfathers Ghost
If one is especially noisy, I would check it to make sure its OK, as well as the rest of that valves parts, the rocker could be bad, excessive wear on the valve tip, ect. ect. As long as every thing seems ok, adjusting is easy. For hydraulic lifters first put the valve you are adjusting on the base circle of the cam, start to tighten the rocker nut while gently spining the pushrod in you fingers. When you can't spin the pushrod any more, tighten another quarter turn and thats it. If you're using poly locks, lock it down. For solid lifters its the same except put the proper feeler gauge between the rocker and valve tip and DO NOT go the extra quarter turn. Make sure you have the right lash number, they vary for cold, hot, intake, exhaust.
Old Apr 14, 2007 | 11:21 PM
80TexasC3's Avatar
80TexasC3
Thanks... they are hydraulic... question...how do I know when I'm on the "base circle"?
Old Apr 15, 2007 | 12:01 AM
Godfathers Ghost
Turn the engine over watching the lifters. When the exhaust valve is begining to close and the intake opening keep going till the intake is closed. Note the crank position. Keep turning till the exhaust starts to open again. Go half way back to the intake closeing point, so you're in the middle of the two points, and you're there for that cylinder. Once you've done it a few times it'll be a breeze.
Old Apr 15, 2007 | 01:15 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Both Crane and Comp Cams have a good procedure for adj hyd lifters on thier w/s and it would be a wast of time to type it here. U can also adj lifters with eng running and i prefer this method. I have a cut open vlv cover just for this that keeps the oil off the exh pipes.
Just make sure u can identify what "zero lash" feels like - u can still roll the p-rod with your fingers before u add that 1/4 to 1/2 turn tight.
As far as the tick noise beaware that it could be a wiped lobe though rollers are much less likely to wipe. Possibly a bad lifter. Try Marvel Mystery Oil? It can work/help to flush out crud from a lifter. Also try a stethiscope to locate the noise source.
that this is partially due to the aggressive cam grind (XE274 Roller) Adj hyd lifters is pretty basic auto mechanics and thier reason for existance is they are quite. Now they do need a little warm-up time but once the eng is at normal temp and lifters are pumped up then lifter noise means vlv train problems.
cardo0
To Adjusting Lifters
