1975 power window ground
Old Apr 15, 2007 | 11:55 AM
njcardave's Avatar
njcardave
Default 1975 power window ground
I see that the ground wire for the power windows is located under the center console under the heat and A/C control. There is also a relay for the power windows. I stated in my last post that my problem is intermitent, both windows either work or don't work at the same time.Can someone tell me if I should focus on the ground wire or the relay? If I need the relay, is it available?
