69 Winshield Washer Pump
Old Apr 15, 2007 | 06:58 PM
SoCalErv's Avatar
SoCalErv
Army
Default 69 Winshield Washer Pump
The 69 is unique as it is a three port with a splitter valve on the other side. Does anyone have a source for this pump and especially the splitter valve?
Does anyone have a good drawing of the system with the hose positioning on the 3 port and splitter valve? The AIM and Chevrolet manual does not give ir justice.
Old Apr 16, 2007 | 10:34 AM
SoCalErv's Avatar
SoCalErv
Army
Need some help.
Old Apr 16, 2007 | 06:55 PM
dd69bb's Avatar
dd69bb
ebay 230116586651
also a seller named belairbobs puts them on
Old Apr 17, 2007 | 11:16 PM
SoCalErv's Avatar
SoCalErv
Army
Thanks.
Does anyone have a good diagram or picture of where the hoses connect to the pumps?
Old Apr 20, 2007 | 09:43 AM
SoCalErv's Avatar
SoCalErv
Army
Someone must have a good diagram of the washer system with a 3 port and splitter valve.
Any help is greatly appreciated.
Old Apr 20, 2007 | 05:44 PM
RPOL68's Avatar
RPOL68
The pump uses 3 ports, one in and two out. The two out go into a "Y" connector then on to the bottom port of an electro-mechanical diverter valve (That's my name for it) on the driver's side of the washer motor.
The two other ports on the valve connect to the wiper arm washer tubes via a tee and other runs forward to the headlamp washers.
The valve just came available about a year ago. Hold your wallet....
Corvette Central
1969 HEADLAMP WASHER SQUIRT PUMP #653123 199.95 EACH
There are good pictures in both the AIM and the Chassis Service Manual. That dingy looking Tee connector is actually a check valve and not yet available for any sources.
Old Apr 20, 2007 | 10:18 PM
SoCalErv's Avatar
SoCalErv
Army
You mentioned a check valve. Is this original? Without it will the water just drain off or take the pump awhile to prime?
Your picture and explanation will give me something to work on Sunday afternoon.
Thank you,
Erv
Old Apr 21, 2007 | 02:13 AM
RPOL68's Avatar
RPOL68
Here is a picture from the 1969 Stingray Guidebook by Rick Bizzoco. If you are serious about restoring your 69 You Need This Book. It's the best $70 you will spend.
Old Apr 21, 2007 | 06:14 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Here's a pic.
The little barrel shaped gizmos are "one way valves". You'll also find them on the headlight washing side of the circuit too.
Keeps the water from flowing back.
Chuck
Old Apr 21, 2007 | 03:23 PM
nuck's Avatar
nuck
Got mine complete from Dynamiccorvettes.com for $294.00. I was referred to them by Corvette America. Most of the other pieces, lines etc can be sourced through Paragon and you can see pics in their online catalogue. Both these firms are reasonably priced and fast shipping. Good luck!
Old Apr 22, 2007 | 11:28 AM
SoCalErv's Avatar
SoCalErv
Army
Think I will buy the book.
Thank you for all the insight.
Erv
Old May 4, 2007 | 11:05 AM
SoCalErv's Avatar
SoCalErv
Army
Received my book yesterday. It is a must have!!
Old May 4, 2007 | 11:16 AM
SoCalErv's Avatar
SoCalErv
Army
Originally Posted by Chuck Gongloff
Here's a pic.
Chuck
Is there a source od one way valves from another application I could acquire?
Old May 4, 2007 | 10:39 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here is a picture of the pump and coil if this helps. It is available new as an assembly only. http://willcoxcorvette.com/product_i...ducts_id=24473
Willcox Inc.
Old May 5, 2007 | 03:31 AM
Chuck Gongloff
Didn't know the pump and coil was available in repro form. Thanks for the info.
The one way valves? They're around. When I go to Corvette flea markets, I always scrounge in the boxes of "junk", or the little pigeon hole boxes many vendors have.
You can find them for 25 cents to $1.00 each. Chuck
Old May 7, 2007 | 07:57 PM
SoCalErv's Avatar
SoCalErv
Army
Corvette Central
What color are the wires that attach to the headlamp pump? Buba has gotten to mine and the are gone or re-wired somewhere else.
Old May 10, 2007 | 10:32 PM
0Willcox Corvette
Former Vendor
http://willcoxcorvette.com/product_i...ducts_id=24206
blue and yellow.
To 69 Winshield Washer Pump
Old May 13, 2007 | 11:32 AM
mrpakchong's Avatar
mrpakchong
8th Gear
If I not want do use the headlamp washer can I just connect the tubes from the pump up to the wiper arms without using the diverter ?
Old May 15, 2007 | 12:17 AM
0Willcox Corvette
Former Vendor
Yes I would think so. The current is the same as the washer pump, but it's not a looped circuit. The washer pump should still work without the headlamp washer hooked up.
Old May 17, 2007 | 08:05 AM
mrpakchong's Avatar
mrpakchong
8th Gear
Thanks,
I will try that, I only need water to get to the front window so I can pass the Swedish inspection for imported cars. Which actually happens next week.
