Brake Line Replacement Question
Old Apr 15, 2007 | 07:20 PM
searay61's Avatar
searay61
Cruising
Default Brake Line Replacement Question
Does anybody have a magic trick to get the long line that runs from the dist block up front to the rear. I've got one of these pre bent ones and there looks like there is no way. It's a 4 speed car so the crossmember is there. The only solution I see is to make it a 2 peice line. Any help would be appreciated!
John
Old Apr 15, 2007 | 07:25 PM
70vert's Avatar
70vert
Banned Scam/Spammer
What year? I replaced my 70 4 speed line without cutting. It's been awhile but I do remember having to bend it and bend it back to get it in.
Old Apr 15, 2007 | 07:54 PM
dannyman's Avatar
dannyman
What year?
On my 77, I disconnected both ends and worked it forward to clear crossmember then fished it out towards the rear. Install the reverse. Didn't have to bend anything very much!
Old Apr 16, 2007 | 08:00 AM
searay61's Avatar
searay61
Cruising
Default Year
It's a 73 4speed big block car...
Thanks!
Old Apr 16, 2007 | 08:41 AM
S489's Avatar
S489
there is no trick; on a 74, a replacement SS line went in okay and SS is less flexible than factory steel lines. unless you have a lift, just jack the car up as high as you safely can. the clamp bolts/screws are close quarters, but that's it . . . just do it as they say . . .
Old Apr 16, 2007 | 03:31 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
When I did my brake lines almost 10 years ago, I didn't bother with that line because it's such a PITA. I kept the new line, and I'm going to do it now that my car is about two feet in the air on jackstands...
Old Apr 17, 2007 | 09:13 PM
77BuffaloVet's Avatar
77BuffaloVet
find some new favorite swear words...
Seriously though...get the car up as high as you can. Be patient. keep pushing and twisting at different angles and it should go through. On my '77 I had to bend the line just a little bith to get it through...
Good Luck
Old Apr 17, 2007 | 11:00 PM
MN80Vette's Avatar
MN80Vette
I heard the Tech Director of our local Corvette club (Classic Corvettes of Minesota) is a having the first tech session of the season this Saturday, and the topic is C3 brake lines.
I plan to attend if I get my master cylinder replaced in time. Do you want me to take notes and pics if I attend? Or do you need to know now?
To Brake Line Replacement Question
