Poly front bushing vs rubber bushing
Old Apr 15, 2007 | 09:22 PM
69 Convertible's Avatar
69 Convertible
Default Poly front bushing vs rubber bushing
Hi all, which would you recomend for the control arm, sway bar bushing ( poly or rubber ). I plan to rebuild my front end and some say that the poly bushing over time squeeks and you have to squirk grease or some kingd of lubericant to stop it from making the noise.Where as the rubber doesn't. Dont plan to autocross, or do heavy twisty. But would like it to handle well. I have the VBP monoleaf in the rear with the Bilstein sport shocks. I plan to put the # 460 coil springs up front and the 1 1/8 swaybar from VBP. Does the poly squeek alot?? Tony
Old Apr 15, 2007 | 09:26 PM
Big2Bird's Avatar
Big2Bird
Lubricate them with silicone grease when installing. No squeeks. They only squeek when installed dry. They are impervious to oil, and virtually forever.
Old Apr 15, 2007 | 10:44 PM
Godfathers Ghost's Avatar
Godfathers Ghost
I'll add a little trick though. The sway bar mounts are low and can get hit with alot of splashed water so if they become a problem, instead of dissassembly you can install grease zerk fittings, which you can do later when neccessary. Drill a hole (the proper size for your fitting, of course) into the mount and through the bushing untill you hit the bar. Clean it out good, then tap it, and screw in the zerk. Just make sure you use the proper grease and cap the zerk.
Old Apr 16, 2007 | 04:37 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Why bother? Just buy the Energy Suspension bushings and shells with the grease zerk pre-installed.
Old Apr 17, 2007 | 02:04 AM
RIJVETTES's Avatar
RIJVETTES
I'm sticking with rubber replacement bushings- especially for a street driven car. I put the greased poly bushings on the control arms in my 93, and they would frequently give an anoying squeek- especially in cold weather. If it was a drag or road race vette, then I'd want a firmer suspension and probably use the poly.
Old Apr 17, 2007 | 03:53 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
That was almost 15 years ago. Materials technology has changed.
Old Apr 17, 2007 | 06:53 PM
WESCH's Avatar
WESCH
Hi
Also it is much easier to install the poly bushings in the A-arms.
For the rubber crap, you need a press.
I also think that the A-Arms moove much more unrestricted and free with the polys .
Günther
Old Apr 17, 2007 | 08:05 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Originally Posted by WESCH
Hi
Günther
...that movement being more consistent and in the wanted directions, not the unwanted ones like rubber. Oh, but you do need to get the original rubber crap out first. My poly's came with new outer sleeves which I tack welded to the arms, per instructions. It's worth whatever little trouble you think it might be to do.
Old Apr 17, 2007 | 08:48 PM
WESCH's Avatar
WESCH
Hi
Tack-weldet ???
My polys also came with outer sleeves. Why would you want to weld them ? They are pressed in till the end and held by the bolt on the opposit side.
Must they be welded ? Did I do this wrong ? Safety ?
The old rubber bushings are normally so worn, that it is easy to get them out, also without a press.
Günther
Old Apr 17, 2007 | 08:52 PM
Godfathers Ghost
I used a VB&P kit, which is what he's looking to get also. Besides, that tip works for many bushing applications.
Old Apr 17, 2007 | 09:40 PM
JustForFun's Avatar
JustForFun
Hi
Tack-weldet ???
Günther
i think the tack weld to help hold the sleeves from rotating which could cause a noise.
Old Apr 17, 2007 | 10:07 PM
TheSkunkWorks
Hi
Tack-weldet ???
Günther
Looking back, I'm thinking my poly's didn't come with new sleeves afterall, because I do have a distinct memory of getting the rubber mess out of them...
Anyway, mine came from Guldstrand, back before poly's became widely accepted beyond hardcore enthusiasts. As much as I'd like to impress everyone with a fine technical explaination (), I can't recall exactly why Dick told me to secure them by tacking them into place (other than to secure them into place). But, I did so and the sleeves certainly don't move or squeek.
I don't think I'd loose sleep over not tacking them in if your kit didn't specify it.
Old Apr 17, 2007 | 10:21 PM
WESCH's Avatar
WESCH
Hi
Puhh, OK.
The rubber bushing sleeves where not welded and there is certainly more rotational force on those as there is on the polys.
The new poly sleeves required some press work as well. I can't see them turning. The poly itself yes, contrary to the rubber just twisting.
Günther
Old Apr 17, 2007 | 10:29 PM
69 Convertible
It's kind of interesting to see the 2 differents in opinion. Which way to go is giong to be a mind strain. But the opinions are greatly appreciated.
Tony
Old Apr 17, 2007 | 10:30 PM
Kid Vette's Avatar
Kid Vette
Here's a good archived thread discussing the pros and cons. Let's Settle This Poly vs. Rubber Bushings Debate
Old Apr 17, 2007 | 11:20 PM
69 Convertible
Hi Vette Kid, Thanks for the thread. They had the same debate then as we do now. LOL
Old Apr 18, 2007 | 02:22 PM
Cris's Avatar
Cris
I’m in the camp of selecting the bushing material by application. On the front A-arms, these bushings only see rotational motion. The way rubber works in this application is it twists as the A-arm moves up and down. Poly, which I’m not a big fan of, acts as a bearing material, the bushing sleeves rotate around the poly as the A-arm moves up and down. No one has mentioned a third choice, and that is Delrin. Delrin is a hard, self-lubricating plastic. It is far superior to poly as a bearing material. Global West makes Delrin bushings for the corvette.
On the rear trailing arms, these bushings see not only see rotational motion up and down, they get “twisted” as well. A spherical solid bushing is the ultimate competition solution, short of that rubber makes the most sense. Poly is not the greatest at handling the twisting motion.
A third set of bushings are on the strut rods. Again these see not only rotational motion but twisting motion. You see heim joint kits as the ultimate solution (VBP and Guldstrand). Again short of that, I’d use rubber rather than poly for these bushings.
To Poly front bushing vs rubber bushing
Old Apr 18, 2007 | 03:08 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The Delrin bushings, IIRC are a pain to install. Poly is easy and wears well - I just restored a set of VB&P adjustable strut rods, old enough that they had the old silver "Vette Brakes and Products" decals, and those poly bushings look like new.
I'm going with the spherical steel in the rear for just that reason. I hate rubber, and I'd like to leave my suspension together this time for as long as possible.
Old Apr 18, 2007 | 04:34 PM
Cris's Avatar
Cris
Yep, the Global West Delrin bushings are a PITA to install. I think they need to be pushed to get their corvette kits cleaned up. The biggest problem is forcing you to weld threaded studs in the cross shafts. For other makes of cars Global West makes special cross shafts. They don't think the corvette market is big enough to justify special parts. (They say everyone is restoring corvettes, not hot-rodding them!)
Poly is certainly durable, I just don't think it's the best for performance in certain places.
Old Apr 19, 2007 | 06:36 AM
Kid Vette's Avatar
Kid Vette
