Yellow vacume line?
Old Apr 16, 2007 | 10:43 AM
dc502's Avatar
dc502
Default Yellow vacume line?
new 77 vette owner, I was poking around under the hood and found what appears to be a pluged vacume line. its really small, at first I thought it was a cut wire. after looking real close it had a pin stuck into the end. Its yellow and is near the alarm hood switch.
I can get a picture after work today if it will help.
Paul
Old Apr 16, 2007 | 12:30 PM
jnb5101's Avatar
jnb5101
how small is it? all rubber vaccum lines are the same size.
Old Apr 16, 2007 | 12:44 PM
SIXFOOTER's Avatar
SIXFOOTER
There are 3 that go in and out of the big gromet just to the pass side of the distributor. 1 goes to the flapper in front of the pass side window for the outside air mix, 1 to the manifold for vac source to the heat/AC controls, and the other one.......Ummmm......Ahhh, Heater shutoff valve
edit, found my pic
This is for 81 but I think its the same
Old Apr 16, 2007 | 12:51 PM
dc502's Avatar
dc502
Ill check that diagram out and see if it matches one of those.
The size of the line is really small, put it this way its plugged with a straight pin.
We I get home from work today Ill take a pic of it.
Thanks for the input
Paul
To Yellow vacume line?
