1980 L48 Performance Mods?
Old Apr 17, 2007 | 03:13 PM
Bowerss2's Avatar
Bowerss2
Default 1980 L48 Performance Mods?
I just bought a 1980 L48 from my uncle. I am looking to increace the performance of the car. I am basically wondering what sort of modifacations are available. Cams, lifters, manafolds, headers, etc. Thanks for the suggestions.,
Steve
Old Apr 17, 2007 | 03:17 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
You can get some more power with cams, intake etc.. but the REAL power is in HEADS and exhaust!! All the duration and lift and duration of a cam or intake won't help you if the heads don't flow enough.. Same goes for the exhaust.
Old Apr 17, 2007 | 05:03 PM
Little Mouse's Avatar
Little Mouse
How much are you willing to do to the engine or spend in money??
replacing the exhaust would be the first thing to do. getting rid
of the 76cc factory heads for modern 64cc chamber heads would
help a lot and the L/48 cam is to mild for any kind of performance
engine. Do you have an auto trans ? whats the rear gearing ?
Old Apr 17, 2007 | 09:13 PM
RedShark's Avatar
RedShark
8th Gear
I heard about Vortec head? but I think that you have to change the intake too..
I plan to put some $$$ on my engine but i'm like you, i don't know where to start (i don't want to spend mors than 2500$)
Old Apr 17, 2007 | 09:18 PM
77BuffaloVet's Avatar
77BuffaloVet
Vortec is great for low end torque, which is great for light to light driving on the street...And yes you need a vortec intake with the 8 bolt pattern.
My set up is "upgraded" vortec heads, Comp Cams XE268 cam and headers on a L48 bottom end. I love the torque. The tires start spinning when I drop the clutch at 1800 RPM's...
If you have more questions pm me and I will answer them...
Good Luck!!!
Chris
Old Apr 17, 2007 | 10:36 PM
Bowerss2's Avatar
Bowerss2
Ya i was thinking about starting with the exaust. Thinking about getting some glass packs, but idk. Who makes headers for the L48? thanks for the suggestions. Oh ya, and unfortunatly its attached to a life sucking auto, more reason i need some performance improvements.
Old Apr 17, 2007 | 10:49 PM
74batmobile's Avatar
74batmobile
u can get a set of headers from hookers( its what i have) and run them to a set of 50 serise flows.....they shound nice youll feel a nice improvemtn on it but like dude said above heads are what u should do....
Old Apr 17, 2007 | 10:52 PM
MN80Vette's Avatar
MN80Vette
You don't need headers specifically for the L48. You need headers specifically for your year of Corvette so the pipes are routed correctly. I just sent another CF member a link to a video of my true-dual exhaust system with Dynomax full length ceramic coated headers (from Summit), 2 1/2" pipes with an H-pipe, and Flo-Pro mufflers.
http://www.flopro.com/FloPro.htm
I like these because 1) they are NOT glass packs, 2) they sound good without being too loud to have a conversation inside the car, 3) performance is excellent with these mufflers.
Total cost of my exhaust system was about $800 from heads to tips including a cross member modification and all custom bent pipes.
My still camera takes great pictures but record lousy sound on videos. My exhaust is actually a little louder and more rumbly than in the video. The H-pipes really smoothed out the sound.
http://s124.photobucket.com/albums/p...t=MVI_0207.flv
Old Apr 17, 2007 | 11:26 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
See the performance mods in my sig for my '80 L48
Seroiusly I got 300 RWHP out of my L48, PM me I will tell you how to get there
Old Aug 15, 2008 | 01:20 AM
tion's Avatar
tion
check corvette central for their true dual exhaust. Fit my 79 like a glove and great sound, not too loud.
Then - budget - get an electric fan, go ebay and get good CFM but single fan (here comes the crap) the money guys go dual....... if a fan belt breaks on stock you are sol - same with single fan. bottom line 10 - 12 HP.
So you pick up 10 on exhaust and 10 on fan with no real changes. 20 hp when you start at 190 is not bad!
Old Aug 15, 2008 | 08:36 AM
tyancey00's Avatar
tyancey00
My 1980 L48 just came from the dyno and produced 300 RWH. 355 TQ. Now if you add 15% for drive line loss she looks pretty good. I have cast vortec heads, flat top pistons, 30 over on the bore, 480 lift crane cam, msd box and coil, Dyno Max coated headders, and it runs good!
Old Aug 15, 2008 | 10:09 AM
Vette79C3's Avatar
Vette79C3
So True...
Old Aug 15, 2008 | 11:48 AM
billla's Avatar
billla
St. Jude Donor '14
It's an SBC - the options are unlimited
What's your budget, intended use and what do you want to keep from the existing engine?
Old Apr 22, 2021 | 06:06 PM
Bmw33813's Avatar
Bmw33813
2nd Gear
Default L48 vs L82- Performance Mods? It won’t let me message you
I’m curious about what you did? It looks nice. My email is bmw33813@yahoo.com
thank you
Old Apr 23, 2021 | 09:05 AM
BKbroiler's Avatar
BKbroiler
Hey bmw, this thread is 13 years old.
Old Apr 23, 2021 | 10:08 AM
Bmw33813's Avatar
Bmw33813
2nd Gear
Im thinking of getting an L48 and was hoping to add some things to make it comparable to the L82
Old Apr 23, 2021 | 10:44 AM
BKbroiler's Avatar
BKbroiler
That's fine, but the moderators here would suggest you start a new thread on that.
To 1980 L48 Performance Mods?
Old Apr 25, 2021 | 02:47 PM
MotorHead's Avatar
MotorHead
2007 wants it's thread back lol
Old Apr 27, 2021 | 10:26 AM
Mr D.'s Avatar
Mr D.
And 13 years later HP still cost money.
Old Apr 28, 2021 | 06:19 PM
vettebuyer6369's Avatar
vettebuyer6369
The thread is still 13 years old, Try starting a new one.
