Need neutral safety switch help
Old Apr 18, 2007 | 06:13 PM
BARRY L-48's Avatar
BARRY L-48
Default Need neutral safety switch help
Checking voltage at the neutral safety switch on my 80 ,automatic.I am getting voltage when I check the green and pink wire,but checking the 2 purple wires there is no voltage,is this the way it is or should I be getting voltage there,any diagrams would be helpful!!
Old Apr 18, 2007 | 07:01 PM
Binnie77's Avatar
Binnie77
The green and pink wires are the backup light circuit. The green should be powered all the time as it comes from the fuse box. One purple wire comes from the ignition switch and should have 12V when the key is in the start position ONLY. The other purple goes to the solenoid terminal on the starter. The circuit is completed when the switch is in the park or neutral position.
Old Apr 18, 2007 | 07:25 PM
BARRY L-48's Avatar
BARRY L-48
I checked the purple wires and both have power when placed in start position,I guess next step is to check power at the solenoid. Thanks for the input on the wiring!
To Need neutral safety switch help
