Carb for C3 L48
Old Apr 20, 2007 | 12:51 PM
heng1's Avatar
heng1
Default Carb for C3 L48
Hi guys
I am having proplems with my Edelbrock performer 600cfm 1405 Carb. and I am wondering if I shouldn't get a new one.( dripping inside)
What would you suggest? I was thinking of a Edelbrock 750cfm or 800cfm? or the Edelbrock AVS Thunderseries 650cfm. 800cfm?
I have a Performer manifold on. The rest looks pretty much stock, but no idea what is inside since I got it second hand. I don't know what cams are in.( how would I find out without taking the engine out?) Eventually I can fix the old one. but in case not, what would you suggest? a bit more power wouldn't hurt the L48 gearbox is stock.
p.s. put a oversize K&N airfilter on top, best investment sofar
Old Apr 20, 2007 | 12:56 PM
TimAT's Avatar
TimAT
If it's dripping raw fuel inside, chances are the float level is too high, or there's some trash in the needle and seat. I've got a pair of these for my BB, and they were a real PITA- I had to use some short rubber lines and the steel line scraped the rubber- little bits got in the needle/seat and made them run over. Once I got it all cleaned out, things were good.
I'd check that first- way cheaper than buying a new carb.
Old Apr 20, 2007 | 01:56 PM
SteveG75's Avatar
SteveG75
No carb will increase power on a stock L-48. A tuned carb will always increase power over a out-of-tune one. IMHO, the best carb is the one GM put on the car, a 750cfm Q-Jet.
SteveG75's Avatar
SteveG75
To Carb for C3 L48
