Yuk need help with leaking head
Old Apr 22, 2007 | 08:17 PM
blueray72's Avatar
blueray72
Default Yuk need help with leaking head
This mistake has really come back to haunt me. I broke off a cheap bolt in my heads trying to mock up exhaust. (just plain stupid)
So I couldn't get it out and had to have a shop fix it
Now I have a water leak coming out of this bolt hole. I'ts a consistent drip. How do I fix this?
btw, New engine runs great!!!! Thanks TimAT for the bench test wiring info. Once I figured out the dist. was in 180 out, she fired right up.
Old Apr 22, 2007 | 08:25 PM
shafrs3's Avatar
shafrs3
High temp Silicone gasket sealer.
Also, you might use some of Loc-tite's green thread sealer on the heli-coil/head interface before using the silicone. The green stuff wicks down between the threads beautifully and is designed to be applied after the bolts are tightened.
Old Apr 22, 2007 | 08:52 PM
blueray72's Avatar
blueray72
Thanks again shafrs3 I'll be looking for that green loctite. I was hoping there was a more permanent fix. Like trying to get something deep into the hole to seal it.
Maybe subconsciously I did this so I could have an excuse to get new heads
Old Apr 22, 2007 | 09:36 PM
TimAT's Avatar
TimAT
the green stuff will work-- so will blue, but you'll need to get it clean and dry. Blue is for hydraulic lines I think.
To Yuk need help with leaking head
