Fuel pump - another question
Old Apr 22, 2007 | 09:25 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Default Fuel pump - another question
This is likely one of the dumbest questions I've asked so far...... which one of the two connections (both 3/8NPT) is inlet and which one is the outlet ???? There were no instructions in the box and I can't find any useful info on Summit's website (that's where I bought it)... trying to find inlet/outlet without disassembling this thing....
Old Apr 22, 2007 | 09:29 PM
TimAT's Avatar
TimAT
Nothing marked on the bottom of the pump I bet. It's too pretty.
I bet the port you can see in the pic is the inlet/suction side.
Old Apr 22, 2007 | 09:31 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I'll look again if I can find something, f.e arrows would be nice...... I thought that the lower port is the inlet but I'm not sure.
Looks like I have to rotate the bottom part anyways to gain more room for my lines........
Old Apr 22, 2007 | 09:47 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i bet if you put a piece of paper taped on one side by the hole and worked the lever it would either suck in or blow out telling you which one it was.
Old Apr 22, 2007 | 10:47 PM
Ironcross's Avatar
Ironcross
Just oink it! The port that ejects air is the outlet.....
Old Apr 23, 2007 | 03:06 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Take a look at your stock pmp if u still have it.
Heck i opened mine (Carter) several times until i got the inlets and outlet where i wanted them to reduce sharp bends in my hoses & lines. But now i can't recall which is which. But don't be afraid to open it up and have a look - its good experience. And i gave my gaskets a light coat of vasoline for preservation. BTW my Carter has twice the number of screw holes so i was able to locate the inlet/outlet within 30* rather than the 60* limited on yours.
Ok heres my guess: Bottom hole is inlet, top is goes out'a.
Good night.
cardo0
To Fuel pump - another question
