Rebuilding Calipers
Old Oct 17, 2001 | 09:26 PM
shoptek's Avatar
shoptek
Default Rebuilding Calipers
I noticed a brake fluid stain of the inside of the L/F tire tonight, so I guess its time for some brake work.
The calipers were replaced with S/S sleeved units about 5 years ago, before I got the car, so I am hoping just the seals are worn.
Has anyone had any luck with the caliper rebuild kits that Vette Brakes sells?
I was looking at the o-ring pistons and rebuild kit. Unfortunately, the car is only driven MAYBE 200 or 300 miles a year, and the o-ring design seems to be geared for cars that sit a lot.
Any and all input will be greatly appreciated!!! :cheers:
Marc
Old Oct 17, 2001 | 09:46 PM
GTR1999's Avatar
GTR1999
Default Re: Rebuilding Calipers (shoptek)
I had SS calipers freeze up from bad brake fluid(moisture build up) and rebuilt them without any problems. I used the brake kits that Muskegon Brake,(Shawn Fox), sells work great and you save $$ over the cost of the kits a lot of other companies sell.I didn't need any special tools just a clean work bench and light.
Gary
Old Oct 18, 2001 | 03:57 AM
mrvette's Avatar
mrvette
Yup, use the O ring pistons and kit from Vette Brakes....toss the springs behind the pistons away, and use DOT5 fluid, it's silicone so will not absorb water....
dot3-4 fluids will.....
GENE
Old Oct 18, 2001 | 08:46 AM
CHEESERAL's Avatar
CHEESERAL
Default Re: Rebuilding Calipers (mrvette)
I used the o ring pistons from Vette Brakes, much better seal than the original, easy, cheap and no problems for 2 years so far. I'd recommend them.
Old Oct 18, 2001 | 10:53 AM
john's '81 mouse's Avatar
john's '81 mouse
"toss the springs behind the pistons away,..."
Never heard of doing this before...........is this advice / recommendation applicable ONLY if installing the O-Ring piston & seal kit, or does it apply equally to a rebuild using the OEM type pistons and seals? Why can / should you throw out / not use the factory installed piston springs? Having rebuilt a couple of these brake calipers myself, I can see why the installation would be easier not using the springs, just wonder about impact of spring removal on brake performance and reliability. Anyone else ever heard of not re-installing these springs????
Old Oct 18, 2001 | 11:00 AM
gkull's Avatar
gkull
I'm at the same point. I've had 3 of my four SS calipers on for about 12 years. I have never rebuilt my own caliper. RedVetteRacer has sets of the O'ring kits for sale. So I'm in the debate mode over rebuild or getting 4.4 pound wilwoods designed for heavy circle track race cars.
Redvetteracer has something like 16 kits for sale.
Old Oct 18, 2001 | 11:32 AM
JME's Avatar
JME
People are inherintly slow to change, so when I read "toss the springs" I thought you were crazy - sort of like "you don't need all 5 of those lug nuts..."
Can you elaborate? I am always looking for tricks that work!
Old Oct 18, 2001 | 04:08 PM
Steve Grodin's Avatar
Steve Grodin
Default Re: Rebuilding Calipers (JME)
I have the original Zero Tollerance pistons and o-rings in my calipers. The instructions said not to use the springs. I have had mine for 8 years. No difference in braking.
Old Oct 18, 2001 | 04:20 PM
CHEESERAL's Avatar
CHEESERAL
Default Re: Rebuilding Calipers (Steve Grodin)
I had heard the same thing about not using the springs with the o ring pistons so I asked the guy at Vette brakes, he told me to reinstall the springs so I did. I haven't had any problems at all with them. I did notice that the o ring pistons when new would stay all the in even with the spring behind them. I don't know if this changes as they get used since I haven't taken them off yet.
Old Oct 18, 2001 | 04:41 PM
Steve Grodin
Default Re: Rebuilding Calipers (CHEESERAL)
One of the reasons to use o-ring pistons is to help eliminate air pumping caused by rotor runout. Without the springs in the the caliper the piston doesn't have constant contact with the rotor. Hence less chance of getting air in the brake system from rotor runout.
To Rebuilding Calipers
