Starter Issues...Need Help
Old Apr 23, 2007 | 01:07 PM
bence13_33's Avatar
bence13_33
Default Starter Issues...Need Help
I installed the mini starter on Friday. I had to clock the starter to make it fit my application. It bolted on fine but it took 7-10 seconds of cranking before it would fire. I know it's not the motor because I had the stock starter from my 350 on and it fired right up. I'm guessing it's not engaging the flywheel because as I'm cranking the oil pressure stays at 0. I stuck two skinny shims in and it made no difference. Does it sound like it needs shimmed out more. It starts but as I pointed out it takes like 7 seconds of cranking before it seems to engage the flywheel and fire up.
Old Apr 23, 2007 | 01:12 PM
S489's Avatar
S489
check cranking voltage at HEI (assuming you have HEI)
Old Apr 23, 2007 | 02:58 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Usually if it is not engaging correctly it will make an aweful sound as the starter teeth grind on the flywheel.
Old Apr 23, 2007 | 03:28 PM
Ironcross's Avatar
Ironcross
Put the OEM starter back on, it works!
Old Apr 23, 2007 | 03:36 PM
bence13_33's Avatar
bence13_33
The problem with the OEM starter is that once the engine gets hot, the starter can't crank it over.
I will check the cranking voltage and I think I may also hook up a remote starter with the car in neutral and on ramps to see what the bendix looks like while it's trying to start.
Old Apr 23, 2007 | 05:16 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
What brand is the mini starter? 2HP, 3HP or 3.5 HP?
Old Apr 23, 2007 | 07:27 PM
Ironcross's Avatar
Ironcross
This is about as far from the truth you can get! Just think, if this was true once a car heated up to operating temperature it would never start.
Old Apr 23, 2007 | 09:07 PM
bozzman3's Avatar
bozzman3
He means once the starter gets heat soaked from the engine it would not crank
Old Apr 24, 2007 | 01:35 AM
Ironcross's Avatar
Ironcross
And I mean there is no such condition. They all get hot, so hot you cant hold them. If the Vette or for that matter any car or truck wont start when hot, get a better battery or have your charging system checked. I have sold hundreds of starters and helped even more on their cranking and charging problems.What I could never figure out is why a person would crawl under a car and remove a super hot starter before checking all the systems and saving from doing a messy job. It takes a lot to kill a good starter and most of the time they are still good. Low voltage is there enemy, not engine heat.
Old Apr 24, 2007 | 01:08 PM
bence13_33's Avatar
bence13_33
Oliver:
The mini starter is a 2HP starter.
I'm telling you that the OEM starter works fine but with the higher compression and a hot motor it can't do it. I never said the OEM starter was bad...I "crawled under the car" to remove the starter while it was cold because I have a nice mini starter that saves me some weight off the front end and doesn't struggle with the 11:1 compression.
Old Apr 24, 2007 | 02:25 PM
GrandSportC3
Oliver:
How is the cranking speed? Is the mini starter cranking slower than the OEM starter? Maybe you'll need a 3 HP starter... 2 HP SHOULD be ok to crank up to 13:1 small blocks but I don't know about big blocks..
I went to a 3.5 HP mini starter for my new engine (13.9 : 1 compression small block)
Old Apr 24, 2007 | 02:43 PM
69 N.O.X. RATT
Heat soak on a starter is certainly a condition, why do you think they make heat shields for starters?? It is normally the selinoid that gets hot and will not work properly.
Old Apr 24, 2007 | 02:56 PM
Ironcross's Avatar
Ironcross
Oliver:
I have personally have over 1/2 a dozen high compression engines {11-1+} and all are equipped with OEM starters directly from our parts inventory identical to those we sell over the counter to the public. There is nothing trick about them except of very high quality. I may be spoiled by offering these units to our customers but they don't fail at any HP rating. I too am also aware there is a awful lot of junk out there. I`m sorry you cant get quality and have to resort to other alternatives. But properly tuned engines are normally running almost before your hand is off the key, that's how good they are.
Old Apr 24, 2007 | 03:12 PM
Ironcross's Avatar
Ironcross
The answer is! Shields are only to protect the solenoid's bakelite cover on the end. Very brittle and heat will cause them to crack . The shield is not for protecting the starter. Ford uses a similar solenoid shield for there 429-460 engines as that starter incorporates a similar GM style switch.
Old Apr 24, 2007 | 04:41 PM
noonie's Avatar
noonie
You need to check the cranking AMPS to tell if a starter is bad or not.
A VAT40 or similar. A lot of parts places will test for free these days.
As Ironcross said the cheapies don't use the proper magnets and poor windings, but don't guess, test it.
Old Apr 24, 2007 | 05:40 PM
69 N.O.X. RATT
I guess we will have to agree to disagree
http://www.google.com/products?q=sta...oogle&ct=title
Old Apr 24, 2007 | 05:46 PM
bence13_33's Avatar
bence13_33
As I pointed out early, the motor is fine and is "quality" as is the starter. As far as OEM being the end all be all, yeah ok.... Go to the track and see how many people are running OEM starters with higher compression motors, there is a reason they are scarce.
To Starter Issues...Need Help
