Installed my Bilsteins this weekend
Old Apr 23, 2007 | 10:05 PM
Lotus76's Avatar
Lotus76
Default Installed my Bilsteins this weekend
I installed my Bilsteins this weekend. WOW!!!
I could not believe how they transformed this vette.
I had rebuilt every area of the suspension and the shocks I had used were ok but do not compare to these Bilisteins. night and day...
I took it out on my favorite tight and twisty s and whooo baby I could not stop smiling, and the ride quality I had never felt in any C3 before.
I was always skeptical about why good shocks cost so much, but not anymore... I wished I had done this a long time ago.
I have read many posts about Bilsteins and the only negatives where cost and by guys that don't have bilsteins... in this case you get what you pay for.
__________________
Old Apr 23, 2007 | 10:06 PM
Big2Bird's Avatar
Big2Bird
Yep.
Old Apr 23, 2007 | 10:17 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Though I've moved on the Koni DA's, it wasn't because I was ever dissatisfied with either of the different levels of Bilsteins I've had. Highly suggest them (for touring or slalom) for any C3 owner who just wants to bolt on an easy and noticeable improvement. Worth every penny!
Old Apr 23, 2007 | 10:20 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
yup, couldn't agree more.....
Old Apr 23, 2007 | 10:30 PM
1fastC3's Avatar
1fastC3
Ive got Bilstein HD's all around and love them, the shocks before were shot so anything wouldve been an improvement but Id used the Bilsteins in the past with great success and highly recommend them. Glad to hear you like yours.
-alex
Old Apr 23, 2007 | 10:51 PM
Vette80regon's Avatar
Vette80regon
Yep. After I changed from the ac delco OEM shocks to the Bilstein Sport shocks I too couldn't believe the difference. It was by far, the best $250 spent on my C3 to date. Hands down. I am continually surprised that more folks here don't make this the first upgrade to their vettes. The difference has been night & day.
I enjoy driving the car so much more.
Old Apr 23, 2007 | 11:30 PM
sjmaster's Avatar
sjmaster
Well....you convinced me, guess I will order up a set in the morning. I have good quality gas shocks on now....but I noticed they don't seem to have much down stroke control. When the front wheels (seem to only notice on front) drops into a small depression, or comes off a concrete curb lip at idle speed, you can feel the wheel drop. My front bushing are OK and not the cause, to the best of my knowledge.
Will the bilstiens stop this??
Old Apr 23, 2007 | 11:52 PM
Scott Marzahl's Avatar
Scott Marzahl
Bilstein Sports Rock, but match your shocks to your suspension spring rate
Old Apr 24, 2007 | 12:11 AM
ikesterx's Avatar
ikesterx
__________________
I'm pondering my suspension woes now. You've sold me on the Bilsteins, but, may I ask what other work did you do to your suspension (upgrades and/or replacements)?
Old Apr 24, 2007 | 06:22 AM
stingr69's Avatar
stingr69
I was also AMAZED. I was hard for me to believe that the shocks would make that much of a difference but they do.
They make the car feel more "expensive". Hard to describe but obvious once you drive on them.
-Mark.
Old Apr 24, 2007 | 08:22 AM
vettfixr's Avatar
vettfixr
I switched from KYBs to Bilstein Sports and was amazed also. I converted my suspension to the front monospring and also had the rear fiberglass spring from a previous upgrade. I was considering the wisdom of this while I had the KYBs because I had a significant amount of bobbing in the rear and the front wouldn't hold on anything but smooth surfaces. The Bilsteins cured all that and gave me a better ride to boot. I wish I had gone with them from the beginning.
Old Apr 24, 2007 | 08:44 AM
mrvette's Avatar
mrvette
Awrite guys, you conned me into it....I"ll give up on my KYB's of some 12 years now, and go the overpriced BILLstein route.....
guess VBP is it....I"m an olde hand there...
Old Apr 24, 2007 | 10:00 AM
Lotus76's Avatar
Lotus76
I started to make a long list but it would be easier just to say I started with the:
VBP Super front end rebuild kit and pieced together the
VBP Advanced street / autocross system
I used 1 inch racing adjustable rear camber strut rods with spherical rod ends and Poly trailing arm bushings.
I run 17 x 8 C5 Y2K Corvette wheels with VPB Corvette wheel adapters and Falker 245/45ZR17 front and 255/45ZR17 rear rubber
I replaced the steering gear and had a good four wheel alignment.
After all that this package did not come together until I installed the Bilsteins.
A comment was made that it "makes the car feel more expensive" that sounds strange but it is so true.
The vette is actually comfortable to drive and handles great!
I wish I had done put on Bilsteins much sooner
Old Apr 24, 2007 | 10:28 AM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
_______________
everybody says that. I don't see how they can give a firmer feel and ride better at the same time.
I think you guys have a good imagination.
Old Apr 24, 2007 | 11:53 AM
Lotus76's Avatar
Lotus76
The VBP catalog states it like this:
"A new digressive valved shock which is self adjusting to road conditions"
In other words it’s MAGIC!
All I know is you really can feel it.
The car is not jumping all over the road every time you hit some rough road (in Michigan that’s just about all roads) so the car control and handling is better and with this type valve on the good roads it just feels like a smother ride, soaks up the bumps.
Best of both worlds (magic) that’s what makes them worth the money.
Old Apr 24, 2007 | 02:37 PM
Scott Marzahl
I assume you installed the Bilstein HDs with the relatively stock suspension. If you are upgrading to stiffer springs the sports are a must.
Old Apr 24, 2007 | 05:22 PM
FKING1's Avatar
FKING1
Ordered a set of Sports today for my 70.
To Installed my Bilsteins this weekend
Old Apr 25, 2007 | 02:06 AM
ikesterx's Avatar
ikesterx
Lotus76, Thanks for the shopping list...now I'll have a good idea of where to start. I can't believe adding the bilsteins negated all the previous effort and expense. But maybe I will start with the bilsteins and work backwards.
Old Apr 25, 2007 | 06:32 AM
Big2Bird's Avatar
Big2Bird
They ARE firmer. I would not say they are "cushy."
Old Apr 25, 2007 | 07:49 AM
DO2G's Avatar
DO2G
I also just installed the sports and notice a major difference. The install was also a piece of cake.
