wiper tray thinks it's cowl induction !
Old Apr 24, 2007 | 10:15 PM
fuelie65's Avatar
fuelie65
Default wiper tray thinks it's cowl induction !
ok Help,
My 72 wiper tray opens up every time I throttle up...
something wrong with the vac lines ?
Old Apr 24, 2007 | 10:59 PM
King Lear's Avatar
King Lear
Veteran
My 72 did that, I put a new check valve on my 72 and it fixed the problem.
Old Apr 24, 2007 | 11:00 PM
fuelie65's Avatar
fuelie65
where the hell is that ???
Old Apr 25, 2007 | 07:56 AM
Tommy Samuels's Avatar
Tommy Samuels
Here's a really good link to vacuum troubleshooting
http://vetteworks.tripod.com/techdocuments/Vaccum.html
It sounds like there isn't enough vacuum "stored" in the reservoir, so likely causes are check valve or a significant vacuum leak.
The high vacuum "stay closed" signal to the wiper door relay is lost when you throttle up, but there's still enough vacuum to drive the actuator.
Old Apr 25, 2007 | 10:05 AM
King Lear's Avatar
King Lear
Veteran
Its the silver connection with two hoses going in one end and one coming out the other, it keeps your vacuum flowing in the proper direction.
To wiper tray thinks it's cowl induction !
