Update on smoke issues with new 383...
Old Apr 26, 2007 | 11:12 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
Default Update THURSDAY 5/17 re smoke issues with new 383...
Well after 2 new sets of heads, 2 new intakes, removing and angle milling the last intake....along with this week I added new valve covers with baffles, a pcv valve...drove for 10 miles tonight...still smoking.
In fact its worse than ever. I had drained the Vavolene 10-30 which had 1 PINT of LUCAS OIL TREATMENT that I added. To see if it slowed down the smoking (and it did) refilled with some sheap STP 10-30 wt.
Car runs good, temp is normal, oil pressure is good...but at idle it looks like a fogging machine, mostly on the drivers side......
I think I have exhasted every possible cause of oil entering the engine, other than past the rings. I may drive it some Friday and see if it improves. I changed the oil to get the super slippery Lucas oil out to see if I could get the rings to seat (if that is the probelm)....and it seems clear there is is a problem in the bottom end. Time to yank it out and take back to the builder.
Would cheap oil cause an engine to smoke, I wouldn't think so...
Thanks to everyone for their help, ideas and support!! Mark
THURSDAY 5/17 UPDATE AT END OF THREAD
Old Apr 26, 2007 | 11:18 PM
dgruenke's Avatar
dgruenke
If it has to come back out anyway, why don't you run it for a few days and see if you can get a lot of that excess oil out of it and see if that helps.
What do you have to lose?
Old Apr 26, 2007 | 11:28 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
drive it for a while, like 50 to 75 miles and dont go too easy on it. if it works then you are in the clear if not then pull it out, but i would drive the crap out of it to make sure all the oil is out. i was told with my last rebuild to run it a few minutes get it warm and then change oil, then let it go for about 300 to 500 miles before the next change. the motor is still running strong and that was 150,000 miles ago. currently getting ready to rebuild it again just for fun.
Old Apr 26, 2007 | 11:34 PM
jackson's Avatar
jackson
Along w/ the good suggestions to verify good crankcase breathing ... Seems upside-down and/or broken ring(s) was fingered.
Old Apr 26, 2007 | 11:38 PM
Big2Bird's Avatar
Big2Bird
Old Apr 26, 2007 | 11:42 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I run a bead of silicone along the bottom of the entire length of the intake gasket on bothe sides so no oil will get into the heads from the lifter valley if the angles of the intake and heads are not bang on. YOu might want to try that, milling the intake indicates you thought the angles were incorrect and maybe they still are
Old Apr 27, 2007 | 04:11 AM
TimAT's Avatar
TimAT
WHo built the short block? I'd have to suggest they either stacked the oil rings, or put all the gaps together. Even with good compression, if the oil rings aren't right it'll pump oil like no tomorrow..
Old Apr 27, 2007 | 04:20 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Did you check valve lash? My #1 intake nut backed off about 1 year after start up....took me a while to find. #1 intake valve wasn't opening at all.
http://temp.corvetteforum.net/c3/the...t/index2.shtml
Old Apr 27, 2007 | 05:26 PM
mbeeman350's Avatar
mbeeman350
Originally Posted by Big2Bird
I know....I know...can't say I haven't tried everything and all the suggestions''' while I waited on my hoist to come home...which will be here Saturday. Thanks for all your help
I had .010 removed to clean it up and to put a litle more clamping force on the bottom edge of the intake. I used a Mr Gasket Ultra Seal. Which has printoseal on both sides. Then I applied ULTRA GRAY slicone to both sides of the gasket...for added insurance for a good deal.
Already talked to him...in fact early on. He stands behind his work! He will make it right, if it something he did wrong..
Engine has good vacuum, idle and runs too good to be runing on 7 cylinders...
Again thanks to everyone for their help and patience, Not trying to beat a dead horse. Had some time waiting for my hoist to come back, so like I said I exhausted every possible cause...Mark
Old Apr 27, 2007 | 05:32 PM
Big2Bird's Avatar
Big2Bird
Old Apr 27, 2007 | 05:46 PM
mbeeman350's Avatar
mbeeman350
Old Apr 27, 2007 | 05:57 PM
Big2Bird's Avatar
Big2Bird
I am funnin.
Old Apr 27, 2007 | 08:03 PM
mbeeman350's Avatar
mbeeman350
I am funnin.
I know....I thought that some of the threads here on the forum were a little over done...think I just got to that point!!
Anyway, taking a break...started pulling stuff off the engine, comes out tomorrow...to the builder Monday!
Old Apr 27, 2007 | 08:09 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Did you do a compression test and a leakdown test? If so and it checked out good I don't have any suggestions. Hope the builder figures it out. Good luck!
Old Apr 27, 2007 | 08:17 PM
Big2Bird's Avatar
Big2Bird
I don't know about you, but I can't wait to see what it tiurns out to be.
He better post pics, or I won't talk to him anymore.
Old Apr 27, 2007 | 08:22 PM
63mako's Avatar
63mako
Me neither! I feel like I worked on it myself and am still pretty frustrated I couldn't figure it out.
Old Apr 27, 2007 | 09:15 PM
BB72's Avatar
BB72
Default Just my 2 cents
The piston oil ring separators have been overlapped, putting less pressure on the oil rings.
To Update on smoke issues with new 383...
Old Apr 27, 2007 | 10:39 PM
mobjack68's Avatar
mobjack68
Thanks to everyone for their help, ideas and support!! Mark[/QUOTE]
4 speed or automatic???
Old Apr 27, 2007 | 10:58 PM
TimAT's Avatar
TimAT
That'd be the "stacked rings" I was talking about.
You're sure getting cranky
Old Apr 27, 2007 | 11:28 PM
Big2Bird's Avatar
Big2Bird
I spent the day clocking, sorry.
