Worn out Idler arm replacement??
Old Oct 18, 2001 | 03:34 PM
daily_driver's Avatar
daily_driver
Default Re: Worn out Idler arm replacement?? (JRChurch)
why do u wanna do it without a special tool???
just stick that pickle fork in there and hammer the 3$#@!@!@@ outta it
:smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash:
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Nope -- go buy a tie rod end seperator and a ball joint seperator. They only cost about $6 bucks each at an auto parts store. They are also commonly refered to as "pickle forks".
You can also use a gear puller, but those are more expensive.
daily_driver
Default Re: Worn out Idler arm replacement?? (daily_driver)
pickle fork costs ~5 bux anywhere.....
Old Oct 18, 2001 | 03:36 PM
john's '81 mouse's Avatar
john's '81 mouse
Probabaly will need a 'pickle fork' made to separate tie rod ends, just wack it good a few times with a 3 or 5 pound hammer. Many auto parts stores will let you rent/borrow these seldom used tools.
Old Oct 18, 2001 | 11:51 PM
Juliet's Avatar
Juliet
While we're on the subject - anyone know where to get a NOS idler arm? Mine was replaced with the current GM part - sans casting numbers and other original features I'm going to loose NCRS points on. :( So far I havent been able to find one. Or I suppose the other thing is rebuilding the original one (I have it saved). I haven't heard of anyone rebuilding them yet either. Any ideas? :seeya
To Worn out Idler arm replacement??
