Differntial Out
Old Apr 27, 2007 | 05:18 PM
SmokinBBC's Avatar
SmokinBBC
Default Differntial Out
6 hours later I finally opened it up. I was having wheel wobble and could see the yokes moving in and out. Yoke end play is .07 and .05. There are no cracks and everything actually looks kinda good for a 37 year old car.
Also, for those of you wondering, there was no gasket on the cover and no leaks.
So what do you think? I plan on replacing the yokes. What else should I check?
In case you were wondering, I am also replacing the ujoints and the halfs and drive shafts. I haven't checked the beaings yet.
Old Apr 27, 2007 | 08:17 PM
GTR1999's Avatar
GTR1999
Replace the yokes, the left one looks worse. Check the cross shaft for wear, Spray some brake cleaner on the windows and cross shaft hole look for cracks, replace the hex head bolts with socket cap screws torque to 60 ft/lbs, check the pinion seal for leaks- mount it on a engine stand pointing down- put in a qt of cheap 90 wt oil let sit 24 hours. If no leak,use a Gm gasket and Ultra black drain the cheap oil out, add 2 bottles of GM additive since you have the springs, and use Lucas 85-140, drive the car and enjoy it.
Old Apr 27, 2007 | 09:09 PM
SmokinBBC's Avatar
SmokinBBC
Will do.
Are the yokes standard or heavy duty? It is a 308, 454/390, MT.
Thanks,
Paul
Old Apr 27, 2007 | 09:18 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Originally Posted by SmokinBBC
Will do.
Thanks,
Paul
Should be Heavy duty with the caps not u bolts. If it isn't now it would be when I was done!
Old Apr 27, 2007 | 09:50 PM
SmokinBBC's Avatar
SmokinBBC
It is the cap type and heavy duty it will be
Old Apr 28, 2007 | 07:17 AM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
Will do.
Thanks,
Paul
If you really want to WAKE it up, call Tom's and get a set of 3.73's!!! Ask me how I know!!!
BTW...Gary set mine up!! (I'm too much of a Bubba to tackle that )
Old Apr 28, 2007 | 08:54 AM
mikebaskette's Avatar
mikebaskette
Default Wouldn't
wheel wobble be more probable in trailing arms?, bearings, incorrect torque on castle nut?, bad trailing arm? Fallen shims? Just a thought
Old Apr 28, 2007 | 11:20 AM
SmokinBBC's Avatar
SmokinBBC
I agree that trailing arms, ujoints and bearings are all suspect. Going to check them all.
There is no wheel wobble while driving..at least from what I can tell. My wife followed me and said she didn't see any strange movement.
The wheel wobble occurs when moving the wheel at the 12/6 position while the car is on jackstands. It is when doing this that I can see the yoke moving in and out.
When grabbing the wheel at the 9/3 postion, there is no noticable wobble.
I haven't pulled the ujoints yet, but the cap movement is erratic, not smooth when turning. My guess bad needle bearings causing the joint to fail.
I think that my problem is a combination of yoke's and ujoints. But I am going to check the bearings.
Old Apr 28, 2007 | 07:03 PM
mikebaskette
Default That is
my guess. Bearing related. Yokes are supposed to move, as you have already pointed out just a bit. Get the half shafts done and check the spindle for play with a gauge. I think it is between 4 and 8 thousands on my '70. When is last time the wheel bearings were greased? I have become a know it all since I have been doing both cars in this area for the last 3 months.
Old Apr 28, 2007 | 07:16 PM
SmokinBBC's Avatar
SmokinBBC
I put a dial caliper on it. .002 and .003. I am not going to mess with them other than to grease the inner bearing.
The joints on the passenger shaft are wasted. One is locked with no movement...going to do them all as well as driveshaft.
I have a full trailing arm overhaul planned for next winter.
Old Apr 28, 2007 | 07:22 PM
SmokinBBC's Avatar
SmokinBBC
I had tall gears on my small block...I don't know what they were, but I liked them off the line. Shredding tires was fun. I like the 3.08 for the longggggg cruises. It still kicks azz though
Old May 6, 2007 | 05:53 PM
SmokinBBC's Avatar
SmokinBBC
Well got it cleaned up and found a crack...
This one looks bad. Look just above the gear on the case.
[IMG][/IMG]
Here is another.
To Differntial Out
