can't open door door stud loose.
I did this last weekend!
Take the door panel off. It can be done but you had better be prepared to replace the panel. I had the panel bent in the shape of the bottom of a shallow bowl. I wouldn't advise doing this if the door panel is in good condition. I had two mechanics and a dealership tell me I couldn't do it too!
If you don't want to do that. Try wedging it open to were you can get a hold of the rod that connects to the inside lock. Keep slamming that rod around. Hard!
I pushed it down too hard or so I thought right as I was giving up hope and it clicked and I jerked the door open.
If you have problems give me a shout and I will help you out the best I can.
William.
Oh, a tire tool works pretty good to pry the door panel back.
Edited in:
You said the door stud was loose, are you talking about the Striker Bolt? What the door lock latches around.
I am not sure if this is a year model specific thing, but on my 74 there is a panel on the inside of the rear fenderwell that I was told gives you access to tighting and moving the striker bolt around. Worth lookin' into.
Last edited by 74Blackfoot; Apr 29, 2007 at 12:50 PM. Reason: Got to thinking more.
