Wiring Harness
Old Apr 29, 2007 | 11:17 AM
woodduck06's Avatar
woodduck06
Cruising
Default Wiring Harness
I have a '75 Corvette that I'm trying to get running for my dad. All of the wiring harnesses were removed when I got to it and I'm working on the interior harness. I was wondering if anybody could tell me where the rear harness and the interior harness connect? Where at in the car do the connections set at?
Thanks,
Mike
Old Apr 29, 2007 | 11:26 AM
Chandler's Avatar
Chandler
hi, I have a 75 with the interior out. What do you want a picture of ?
I'll take a picture and post it for you.
Old Apr 29, 2007 | 11:51 AM
Chandler's Avatar
Chandler
any of these help?
Old Apr 29, 2007 | 05:54 PM
Red70vette's Avatar
Red70vette
I suggest you invest in an AIM (Assembly Instruction Manual). You can get them from most Corvette vendors, or the NCRS website. If you are going to reassemble the car you might as well do it the way they did it at the factory.
It will be the best $25 you will every spend if you are going to wok on the car yourself.
Old Apr 29, 2007 | 06:07 PM
Durango_Boy's Avatar
Durango_Boy
All the harnesses on my '77 came together at the fuse block under the driver's knee pad on the inside of the firewall. I would assume it's the same for you.
Old Apr 29, 2007 | 07:01 PM
Duke94's Avatar
Duke94
Plugs in on left side under dash. Here's the AIM for my 71'. Yours should be the same.
Old May 1, 2007 | 01:53 AM
woodduck06's Avatar
woodduck06
Cruising
All of these pictures are perfect! Thanks guys, it's been a great help.
To Wiring Harness
