Well, my 76 stock corvette doesnt pack the punch i would like to have, so i was wandering if someone could give me a few things that would increase horsepower without killing my pockets. Im really just looking for the most bang for my buck, probably around the $500 range, should i just save my money?
You need to get some true dual exhaust on there. The stock exhaust was pretty restrictive. You can have an exhaust shop make the pipes, get an "off-road" dual exhaust system from Mid America, or you can just order the stock exhaust components for a 1974 (no catalytic converter).
If you keep everything else stock, you probably won't need headers at this point. After you have the exhaust put on, that opens up the door to future upgrades such as intake manifold, cam and heads.
I put on a true a dual system - 2.5" aluminized pipe w/magnaflows from Corvette Central. No catalytic converters. Bolted right up to the factory exhaust manifolds with no modifications. BIG difference. After that, check your timing and carburetor adjustment. If needed, rebuild your carburetor and/or distributor. The originals, properly functioning, are as good or better than a lot of the aftermarket stuff you can buy today.
If you can do the work yourself, the above will set you back about 500-700 dollars and you are looking at 220-250 rwhp depending on whether auto or manual
Not only will your Vette run better but it will sound like what a Corvette should sound like! Best change I ever made to mine and it cost around $325 including shipping..
From: Graceland in a Not Correctly Restored Stingray
Originally Posted by Dell Boy
If i was in your position,the first thing i would fit would be a
true-dual exhaust system and headers,but thats just me.
Plus a K&N filter and some fine-tuning of the ignition and carb. are the first places to look for power on a budget. But stay away from "quick advance" kits.
You do have cold air induction, right?
AMEN i bought the true duals from Mid America, it made the biggest difference than any other mod I have done, (bsides the new suspension from VBP
The one single best performance boost you can make to your car is not under the hood. Making a Vette "sound good" doesn't make it go faster. It just makes it noisier. Before I lifted the hood and even touched the motor, I'd take a look at the back of the car. Most likely you have a cruiser gear in the rear end. Something that gives great mileage but kills good performance. Switching to a high 3 series (3.73, 3.91) or low 4 series (4.11, 4.33) will give the most dramatic performance change you can readily see and feel. Definitely do all the other stuff that these guys suggested, just start at the back and work forward
BTW...K&N filters gets marginally better "performance" by letting in more air...and more DIRT. This has been discussed at length on the forum. Do a search if you don't beleive me
Also, a stiffer gear in back will reduce your gas mileage. But you didn't buy a Vette for it's great gas mileage, did you?
On street tires, my 0-60 times suffered slightly when I changed from 3.55 to 4.11, and I saw no significant improvement in 1/4 times. But, I did lower my top-end and spend more money on gas. Went back to the 3.55. On slicks, I'm sure it would have been better, but if you can't put the increase of multiplied torque down, you won't see real gains. So, I'd consider traction before re-gearing.
So what you are saying in a roundabout way, is you bolted in a 4.11 gear and used street tires at the strip. And they went up in smoke. That is a result of a lot of power getting to the rear wheels. Bolt some slicks on and then go to the strip.
What does "I'd consider traction before re-gearing" mean??? You aren't gonna have traction problems with a cruiser rear gear. Heck, this guy sounds like traction problems are the least of his worries.
I would have to agree (being a 76 owner myself). When I first got my 76 4-speed it was an absolute DOG. First thing I did was intake and exhaust (and For about $500) buy a edelbrock performer rpm intake and a reconditioned holley 600 or edelbrock 600. Then remove cats (if possible) and replace old muffler with flowmaster 40's...I swear when I did this to my 76 it felt like it gain 100hp.....(although probably more like 40hp).
Before you presumed I'd made such an elemental rookie mistake, you didn't bother to take into account that, during the 20 plus years spent drag racing and road racing, I might have learned just a little about tires and traction and throttle modulation and gearing and power. So happens that I've been through a few sets of 14x32W's in my time, thank you.
The reason I sited the particular street car example in question was that the original poster's inquiry didn't necessarily appear to be for a car on slicks at the strip. Hence, the limited traction of steet tires and compromises of a shorter gear could both come into play, depending on how performance is defined.
Hope that puts my previous post into better perspective...
Me too, Corvette Central System with Magnaflows, fit was great , easy to do and Sounds like a Corvette should !!!
