Timing light question
Old Apr 30, 2007 | 09:42 PM
sperkins's Avatar
sperkins
Default Timing light question
With the battery behind the seat, where do you guys hook up your timing light leads?
Old Apr 30, 2007 | 09:47 PM
Georgia1974's Avatar
Georgia1974
I hook the positive to the positive terminal on the alternater. The ground on the alternater bracket
Old Apr 30, 2007 | 09:58 PM
SIXFOOTER's Avatar
SIXFOOTER
yea, just be very careful not to let the timing light clip ground the alternator, it lets out the majic smoke
Old Apr 30, 2007 | 10:14 PM
chrisd0729's Avatar
chrisd0729
Great idea... I pulled the battery out of my CJ in the garage and set it on a wood block next to the vette and ran the power leads from that (before anyone asks, cyl 1 connection was on the Vette's cyl 1 and not the CJ's )
Old Apr 30, 2007 | 10:25 PM
BarryK's Avatar
BarryK
that's how I do it
Old Apr 30, 2007 | 11:16 PM
Glassbowtie77's Avatar
Glassbowtie77
Me too.
Old May 1, 2007 | 08:08 AM
sperkins's Avatar
sperkins
I once read an article on how they actually put that smoke in there. Pretty interesting process.
Old May 1, 2007 | 08:28 AM
Poppa Bud's Avatar
Poppa Bud
Cruise-In IX Veteran
St. Jude Donor '08 thru '13
I use the hot terminal on the horn relay. Keeps the wires a little further away from the belts & fan.
Old May 1, 2007 | 08:52 AM
jack 69's Avatar
jack 69
Old May 1, 2007 | 10:01 AM
dgruenke's Avatar
dgruenke
That's also how I do it.
Old May 1, 2007 | 10:36 AM
77BuffaloVet's Avatar
77BuffaloVet
I lengthened the positive wire and hook it to the battery behind the seat. The negative wire goes wherever, usually the steering box...
Old May 1, 2007 | 11:38 AM
sperkins's Avatar
sperkins
The reason I asked was that I tried to use jumper cables from the battery and for some reason it didn't work. I've done that in the past with no problems.
Also, for those who've already let the smoke out of their wiring harness, here's where you can get replacement smoke.
http://www3.telus.net/bc_triumph_registry/smoke.htm
To Timing light question
