New Distributor Gear?
Old May 1, 2007 | 12:18 AM
C371's Avatar
C371
Default New Distributor Gear?
I lost an exhaust lobe on the #7 cylinder last weekend. Not sure why? I'm going to order a comp cams hydraulic roller. I know your are supposed to replace the distributor gear with a new cam shaft. In the past I seem to recall you should use a bronze gear with a roller cam. Is this still the case?
TIA
Old May 1, 2007 | 02:13 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
TIA
If you're going to use an austempered cam, you can use a stock type gear. Be sure to get a new one.
If you go steel core (something I'm contemplating despite an austempered core being available for the solid roller I'm looking at), you'll have to go bronze or Ultra-Poly, or the gear won't last but a few short miles.
Old May 1, 2007 | 09:46 AM
bashcraft's Avatar
bashcraft
http://forums.corvetteforum.com/show...4&goto=newpost
Old May 1, 2007 | 10:39 AM
jackson's Avatar
jackson
According to Sallee (now Gilbert Chevy) a steel roller can be used with GM melonized steel dist gear (see that site's main cam page). BTW ... every one of several genuine GM sbc roller cams I have looked at appear to be made of steel ... also each individual lobe appears to have been induction-hardened. However, I have yet to ABSOLUTELY determine if those same cams have a pressed on cam gear.
But ... with cam in hand, I just looked CLOSELY at Unused GM roller cam P/N 14097395 ... It is a roller cam and it appears to be steel ... I cannot see any evidence of any seam or parting line where gear and/or rear journal may've been pressed on ... entire cam with gear appears to be a single discrete piece and is fully-machined from one end to the other; including in-between each lobe. FYI: Cam 14097395 comes in HT383 crate ... GM recommends HEI distributor P/N 93440806 for HT383 ... and that dist comes with melonized steel dist gear P/N 10456413 .
*refs: 2007 GMPP hardcopy catalog, Gibert/Sallee website main cam page.
Old May 1, 2007 | 10:41 AM
jackson's Avatar
jackson
I'm still waiting on CC & a few others ... I definately haven't forgotten ... maybe they have.
Old May 1, 2007 | 02:15 PM
TheSkunkWorks
He's getting the cam from CompCams. They offer austempered cores, which allow for use with most standard gears, as an option to steel cores for certain applications such as for many street roller grinds, hydraulic or solid. Look for -8 suffix for these. If you see a -9, that's going to be steel and will require bronze or Ultra-Poly...
Old May 1, 2007 | 02:51 PM
jackson's Avatar
jackson
Learn a bit of basics about Melonizing / Melonite treatment here:
http://www.burlingtoneng.com/melonite.html
I spoke with tech support at corp GM Powertrain this afternoon. The roller cam I mentioned above is steel, is one piece, is induction-hardened ... its gear also hardened ... cam supplied to GM by Federal Mogul & is also etched w/ Federal Mogul numbers.
-edit-
  • The -9 CC steel cam has a steel gear.
  • The above one-piece steel GM roller cam has a steel gear.
  • GM recommends a steel melonized dist gear for above GM cam.
  • It seems all GM roller V8 have steel roller cams.
  • GM recommends a steel melonized dist gear for all GM crates w/ steel cam.
Other than "comp said so" or "comp offers to sell steel -9 w/ a cast pressed gear for $50-$100 more" ... Can anyone offer technically-rooted reason(s) why a melonized steel dist gear should not be used with a steel-gear steel roller cam (ie -9 steel CC)?
Old May 1, 2007 | 04:05 PM
TheSkunkWorks
...Other than "comp said so" or "comp offers to sell steel -9 w/ a cast pressed gear for $50-$100 more" ... Can anyone offer technically-rooted reason(s) why a melonized steel dist gear should not be used with a steel-gear steel roller cam (ie -9 steel CC)?
Not saying other materials won't work. Just passing on info from my personal experience and product knowledge with these particular cores. Having once lost an IHRA World Finals championship round due to distrubutor gear "failure", I tend to pay fairly close attention to what the manufacturer of a specific cam (CompCams, in this case) recommends here. The melonized piece may be fine...
Old May 2, 2007 | 10:03 AM
bashcraft's Avatar
bashcraft
Do you think Comp Cams is going to recommend a part that they don't manufacture and won't make any profit from?
To New Distributor Gear?
