Spedo gear change
Old May 1, 2007 | 05:53 PM
Leo001's Avatar
Leo001
Default Spedo gear change
I just had a new set of gears installed (3:73) do I need a new gear in the trans (4sp) for the sreedometer to be correct?
Leo
Old May 1, 2007 | 07:44 PM
C3 Stroker's Avatar
C3 Stroker
Leo
Yes, you need a new speedo driven gear with any rear ratio change for accurate speedometer readings.
Old May 1, 2007 | 08:57 PM
71406's Avatar
71406
If I remember correctly Dr Rebuild has a great selection of these gears.
Old May 1, 2007 | 09:03 PM
DARROW's Avatar
DARROW
should be a # 22
Old May 4, 2007 | 07:22 PM
Leo001's Avatar
Leo001
#22 or onn with 22 teath, I notice the come color coded, is each color coraspond to a different rear end ratio??
Leo
Old May 4, 2007 | 10:04 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you ever want to check these, we have the 4 speed charts listed under our repair help section. Just enter the year, then repair help and search for speedo. They are there for all 1968-1977 cars.
http://willcoxcorvette.com/advanced_...eywords=speedo
Old May 5, 2007 | 08:29 AM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
Leo
22 tooth silver gear. There is a 22 tooth green gear also, not sure if there is a difference. I used the silver 'cause it looked better with my blue 'Vette!!!
It seems to be close, but I haven't been out with my wife following me to give it a check. It was also recommended that I go 120mph on the highway till I find a State Trooper...he'll tell me EXACTLY how fast I was going!!!
To Spedo gear change
