Another Compression Question!!!!
Old May 1, 2007 | 07:05 PM
blueonblue's Avatar
blueonblue
Default Another Compression Question!!!!
I have tried using the compression programs recommended on this forum, but it seems that I get different results or the results seems like it cannot be right. Last time I tried I got a DR of over 11.0:1 and a static of around 7.1. Can this be right?
Bore: 4.030
Stroke: 3.75
Pist Vol -5
Pist Compression Height: 1.425
Cam:
Comp Cams 270 Magnum Hyd. Flat Tappet
Int. 224@ .050 Exh. 224@.050
Heads:
World S/R Torquer: 67cc Cast Iron
Head Gasket: .041 with 4.166 Bore
Advance: Hopefully 32-34 Degrees
Any help greatly appreciated. I just want to make sure I can run with premium fuel.
As always, Thanks in advance.
Old May 1, 2007 | 07:14 PM
oregonsharkman's Avatar
oregonsharkman
I feel your pain brother I just went throught the same thing. The CR programs available all disagree with each other. I got anywhere from 10.2 to 11.8 SCR on my build....It is NOT 12.8 or 10.2. My best guess right now is about 10.7SCR.
BTW are you sure your DCR and SCR aren't backwards??
A DCR of 7.0 will run on pump gas.....If your DCR is really 11.0:1 then you better fill up on the 115 leaded
BTW DCR will always be lower than SCR
Good Luck
Old May 1, 2007 | 07:17 PM
oregonsharkman
After looking at your specs again there is no way that you are 11.0:1 SCR.
Even at zero deck with 67cc heads and an .041 head gasket you should be more like 10.2 (with -5cc flat tops)
Old May 1, 2007 | 07:46 PM
blueonblue's Avatar
blueonblue
Yes I did get the static and dynamic backward. Even so it still would seem that a dynamic of around 7.1:1 and static of over 11.1:1 would not be right with a short cam like this one.
Old May 1, 2007 | 07:52 PM
blueonblue's Avatar
blueonblue
I almost forgot this spec. The deck is stock, which should be 9.025, right? I could not find a machine shop to deck the block without taking of the numbers. It was checked and found to be OK.
Old May 1, 2007 | 09:26 PM
oregonsharkman
Cam or not this does not sound right...I really think that your SCR will be under 10.5.....Your DCR under 8.3
Old May 1, 2007 | 09:59 PM
blueonblue's Avatar
blueonblue
I agree. The piston mft. states 10:1:1 for a 68cc head. I was just concerned about using pump fuel, and was trying to figure dynamic compression. Guess I was just putting the wrong figures somewhere.
Thanks anyway
Old May 1, 2007 | 10:00 PM
Bullyj's Avatar
Bullyj
Old May 2, 2007 | 12:06 AM
dgruenke's Avatar
dgruenke
My calculations show a SCR of 10.1:1 and a DCR of 8.34:1.
I think you are running a little high for iron heads and no quench effect.
Old May 2, 2007 | 12:23 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
You use 5cc NOT -5cc in the calculator. It is piston volume. That is why your static compression is coming out so hi. -5cc volume is a dome piston. Double negative is a positive. Math 101.
Old May 2, 2007 | 12:27 AM
63mako's Avatar
63mako
Stay under 8.0 MAX for iron heads 7.8 is safer. You need a bigger cam or lower static compression for sure.
To Another Compression Question!!!!
