Fram HP4 Racing Filter
Old May 2, 2007 | 11:57 PM
71LS5's Avatar
71LS5
St. Jude Contributor
Default Fram HP4 Racing Filter
Hi,
I just found this filter at AutoZone and was wondering if anyone has used it. The Fram HP4 looks AWSOME and VERY well made. Its got much better flow characterisitcs (the flow holes are much larger than even the PF35 ACDelco unit by far, low restriction filter media, more capacity also and heavy duty threads and a bypass valve. I am very impressed and will be putting it in tomorrow as I am going to the Dyno Friday.
Old May 3, 2007 | 01:08 AM
a smith's Avatar
a smith
Your engine, your choice. Vegas
Old May 3, 2007 | 02:05 AM
71LS5's Avatar
71LS5
BTW i am not selling anything here just noticing the quality of what is typically poor quality oil filters.
Old May 3, 2007 | 02:24 AM
Vesa's Avatar
Vesa
I have used those - so far no problems...
Old May 3, 2007 | 05:51 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Shy of spending the money for a Canton, highly recommend a Moroso.
http://www.moroso.com/catalog/catego...?catcode=20002
Old May 3, 2007 | 11:51 AM
71LS5's Avatar
71LS5
I was not aware that Moroso made oil filters. I will have to check those out and get a few. I change my oil every 2500 miles.
Thanks!
Old May 3, 2007 | 11:03 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
As others have mentioned look for WIX filters. The HP oil filters are just that HP filters. They are designed to withstand high pressure. I do run an HP-1 but it is on a full flow Air-cooled VW. A standard filter would just simply explode lol.
Old May 3, 2007 | 11:32 PM
TheSkunkWorks
Just a note: Moroso's filters are not only "HP" designs, but they also provide very good flow rates since they don't over filter the oil.
Once had an AC explode at speed. Fortunately, it flamed (impressively, I might add) so it didn't oil the tires as bad as it could have. Wish I had that one on video...
Old May 4, 2007 | 12:19 AM
68 Yellow 468's Avatar
68 Yellow 468
Originally Posted by 71LS5
Hi,
I run that filter on my car as well......
B.
Old May 4, 2007 | 12:36 AM
TheSkunkWorks
Just some food for thought...
The Fram HP4 filters (unnecessarily) to 15 microns, the Moroso to 27 microns. Seems fitting you'd have to run dual Frams (something I used to do) to out-flow a single Moroso, without the bypass valve compromising filtration.
To Fram HP4 Racing Filter
