76 horn relay
Old May 3, 2007 | 12:53 PM
dewayne1970's Avatar
dewayne1970
Default 76 horn relay
76 corvette, where is the horn relay located?
Old May 3, 2007 | 01:48 PM
76muscle's Avatar
76muscle
Just above the fuse panel.About 3 inches up the wire harness you should see the relay.It has two release clips one on each side.The top of the relay faces forward.
Old May 3, 2007 | 01:49 PM
Doc Rebuild's Avatar
Doc Rebuild
Right above the fuse box. About half the size of a pack of cigarettes; encased in plastic with 3 bayonet spade terminals protruding.
Geoffrey Coenen
Old May 3, 2007 | 04:15 PM
dewayne1970
O.K. Thanks
To 76 horn relay
