Transmission Leak
Old May 3, 2007 | 11:02 PM
rjken1969's Avatar
rjken1969
Default Transmission Leak
I have a '75 L82 with a 4-speed. The trans appears to be leaking at the rear, where the drive shaft is inserted. Any ideas on this? Is the seal in this location a difficult one to replace, or is it an easy fix?
Old May 3, 2007 | 11:08 PM
SIXFOOTER's Avatar
SIXFOOTER
Easy fix. Drop the driveshaft. pull the yoke out of the tranny and pop the seal out with a screwdriver. Knock the new one in with a hammer and block of wood. 30 minute job
Old May 4, 2007 | 03:35 PM
rjken1969's Avatar
rjken1969
Ok, that's great. Sounds easy enough.
However, all 30 minute jobs seem to wind up taking hours on the boat.
Thanks.
Old May 4, 2007 | 05:02 PM
supercalvin's Avatar
supercalvin
I hear ya there.
Not to mention all the "while I'm at its"
Old May 4, 2007 | 08:57 PM
Duke94's Avatar
Duke94
Thanks.
You could always take it to a trans shop and have them fix it. You are correct; working on a 25-30 year old car always brings surprises.
Old May 5, 2007 | 12:07 AM
TimAT's Avatar
TimAT
Drop the drive shaft, pop the old seal out with a chisel/screwdriver, pack the back of the new seal with grease, drive it in, put the driveshaft back in. Go have a beer or 5
Old May 5, 2007 | 08:26 PM
rjken1969's Avatar
rjken1969
It seems like when I complete any project on it, when I'm done I have a beer or five. Even if its giving it one of it's winter warm up starts.
Start the motor, drink a beer, and listen to it run.
Old May 5, 2007 | 08:28 PM
rjken1969's Avatar
rjken1969
Originally Posted by supercalvin
I hear ya there.
Amen to that.
I wanted to put some modern rubber on.
Well, modern rubber calls for larger wheels with low profile tires. Which calls for a lower suspension. Which calls for all new springs and shocks. Which calls for......
It never ends.
To Transmission Leak
