Stuck in Gear - Help
Old May 5, 2007 | 08:10 PM
79vetter's Avatar
79vetter
Default Stuck in Gear - Help
Today I put my 4spd. transmission + clutch back in and I was re-connecting the driveshaft back to the transmission yoke. I grabbed the shifter rod for 3/4 gear to put it in neutral, then I was able to rotate the trans. yoke to mate the driveshaft + u-joint. I put it back in gear by moving the 3/4 rod again and then I tightened one side of the U-Joint. I then put the rod in neutral again so that I could rotate the driveshaft but it ain't movin' now. I got out from under the car and checked that the shifter was indeed in Neutral. Then I tried rotating one of the tires forward (car is on stands) - won't budge either.
I have checked and double-checked that I am in Neutral but it feels like I am still in gear. P/Brake is not on. I must be missing something
Old May 5, 2007 | 09:06 PM
SIXFOOTER's Avatar
SIXFOOTER
you got it stuck in 2 gears. get back under there and make sure both levers are verticle. Happens a lot on some manual cars with some wear in the shift linkage
Old May 5, 2007 | 09:10 PM
lucky76's Avatar
lucky76
Easy to do, put each one back to the neutral position and go from there.
Old May 5, 2007 | 10:59 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
they are right...... get under neath and make sure no plastic bushings or circlips have walked away.
To Stuck in Gear - Help
