update on idle quality.....interesting
Well, the problem was the wrong carb to manifold spacer / gasket.
Mine had a spacer type gasket, about 1/2 thick.I had no idea if this was stock or not on a 1977 era intake and carb. It was completely cut out in the center, no division between any bores. I replaced with a standard Q jet gasket about 1/32 thick, with division between all 4 bores and much more area under the carb. Presto....idle perfect, a bit better acceleration and overall operation.
PS, I had planned on sorting this out, so I ran the tank nearly empty and filled up with no additives last Thursday.
What got me going was actually a post about about idle not going below 1000 even with no screw contact, and this being a sure sign of a air leak. I had the same issue, although I was around 800-900, so it was tolerable. My idle will go as low as I care. The spacer gasket had hard bushings that were preventing the crush needed on the old gasket / spacer material. I am assuming this was one of those products designed to insulate carb from heat. Mine is hot restarting fine...soo it was not needed I guess.?
I hope this helps someone out !!
You could get a good idle in the garage & then go for a test drive & the idle would just go to hell. Is it one of those thick gaskets that come in the carb kits? Thats what I was useing. Went & got a Mr Gasket thin 4 hole gasket figured what the heak I've tried everything else. & it worked! Much more stable idle.
Also my engine seems sensitive to underhood heat. So the factory 76 single snorkel air cleaner with the over the radiator airbox is going back on as soon as my air cleaner - airbox hose gets here.
