1980 L48 Engine Mount Replace
Old May 7, 2007 | 12:12 PM
Darrel1's Avatar
Darrel1
Default 1980 L48 Engine Mount Replace
1980 L48 2004R
Will performing my pressure check procedures from BTO on my new 2004R- I noticed that while doing the 1500 rpm check the engine lifted on the driver side seems like a 1.5 inches- so my engine mount must be bad.
Are there any tricks to replacing the engine mount.
1. support engine at oil pan? (what is the best way to do this?)
2. Remove bolts
3. insert new mount
4. replace bolts
Any other tricks or is this more difficult than it sounds
Darrel1
Old May 7, 2007 | 02:19 PM
Jims79's Avatar
Jims79
Originally Posted by Darrel1
1980 L48 2004R
2. Remove bolts
3. insert new mount
4. replace bolts
Darrel1
That's the way I chg'ed them. pretty easy job I would replace both sides while your at it. G/L
Old May 7, 2007 | 09:55 PM
77BuffaloVet's Avatar
77BuffaloVet
As simple as you put it, that is what you do. My only suggestion would be to lossen the transmission mount bolts so that you can move the engine a little. Makes it easier to get the bolts in.
It is not a lot of fun...especially the driver's side...
Good Luck!!!
Old May 7, 2007 | 10:58 PM
Darrel1's Avatar
Darrel1
Default Where do you lift the engine from??
I was under the car tonight and could not figure out a way to lift the engine without denting the oil pan. Am I missing something? Where do you lift from? front of the pan or behind the steering arms?
Need some help
Darrel1
Luckily I had some othe things to do so I did not waste too much time.
Old May 7, 2007 | 11:36 PM
sjmaster's Avatar
sjmaster
I just did my 81 in February, used the red urethane ones, the brand escapes me right this second. I lifted the engine as required with a 1/4 thick 6 x 10 inch piece of aluminum plate I had handy and bottle jack.
You will need to loosen the trans mount....and you should just do it the same night. Mine was shot
The drivers side went quick, the pass was a PAIN. I got smart around 3am and bevelled the tip of the last bolt I was trying to get into the motor. This did the trick. The precision of the holes in mine was remarkable....no slop, which made it difficult on the pass only. In retrospect, I would have hit both side of all mounting holes with a countersink bit, bevelled the tips of all three bolts, and maybe the through bolt as well.
The trans mount was fairly easy, but again, I would countersink holes slightly to get rid of 90 degree edge and bevel mounting bolts. If you loook around the vehicle, most of the stock hardware has some sort of reduced tip to ease insertion.
Old May 7, 2007 | 11:44 PM
MN80Vette's Avatar
MN80Vette
Need some help
Darrel1
I changed the mounts on my '80 last year by putting a block of wood on the oil pan rim in the front. No problems, no bends. If your motor mounts are shot, you may as well replace the trans mount too.
Old May 8, 2007 | 02:28 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
You might want to remove the fan so as not to crack the shroud.
Old May 8, 2007 | 07:57 AM
MN80Vette's Avatar
MN80Vette
Good point. I don't have a clutch fan or shroud, so I never thought of that.
Old May 8, 2007 | 09:59 AM
Darrel1's Avatar
Darrel1
Thanks for all the ideas. I just put a block of wood under the oil pan and it seemd like the pan was going to crush in when I started to lift so I stopped and decided I need to ask my fellow members.
Darrel1
To 1980 L48 Engine Mount Replace
