Test and Tune results
Old Oct 20, 2001 | 12:04 PM
nastee383's Avatar
nastee383
Default Test and Tune results
Went to test and tune last night in my quest for a 7.999 all motor. Well, it didn't happen. Had a couple of 8.15's. I also ran an 8.70 @ 79mph. I went back to the pits because the car was stumbling. Come to find out I had accidentally knocked the no. 1 plug wire off the distributor. I guess a 8.70 with a 1.93 60' isn't bad for 7 cylinders.
Anyway I decided to use some squeeze on my last two runs. I ran a personal best of 7.366 with a 125 shot. Here's the breakdown:
Reaction .083
60' 1.553
330' 4.689
1/8 mile 7.366
MPH 91.67
I made another pass with the bottle pressure increased to 950 (from 800) but it spun (1.682 60') and only managed a 7.502. I leave at 16 -1800rpm and shift @ 5600 rpm. By the way, out of 5 passes, three Mustangs were killed.
Old Oct 20, 2001 | 02:04 PM
krafty79's Avatar
krafty79
Default Re: Test and Tune results (nastee383)
nastee, great numbers! and great kills on the moosestangs...
was curious, what tire pressure do you run at?
thanks and keep up the great work.
krafty
[Modified by krafty79, 12:06 PM 10/20/2001]
Old Oct 20, 2001 | 02:57 PM
Gordonm's Avatar
Gordonm
Default Re: Test and Tune results (krafty79)
:eek: :eek: Those are good numbers only running on 7. With nitrous impressive. Is that a roller cam you are running.
Old Oct 20, 2001 | 04:23 PM
nastee383's Avatar
nastee383
krafty
Thanks. 21.5 psi just motor, 17.5psi on squeeze.
Old Oct 20, 2001 | 04:28 PM
nastee383's Avatar
nastee383
Default Re: Test and Tune results (Gordonm)
Thanks. Cam is a hydraulic flat tappet. Way too mild for most tastes, but it gets the job done!
Old Oct 20, 2001 | 06:03 PM
Gordonm's Avatar
Gordonm
That is even more impressive with a flat tappet hyd. cam. Gotta build a 383 out of mine someday.
Old Oct 20, 2001 | 07:25 PM
QuickVet's Avatar
QuickVet
Nice Job! i need a 383 as well. mabey i will run into some money one day. enjoy :cheers:
To Test and Tune results
