Drop base air filter / cold air kit.
Old May 9, 2007 | 11:51 PM
L Holmes's Avatar
L Holmes
Default Drop base air filter / cold air kit.
Thinking about trying to get some cold air to my carb on my 70 LT1 car. I have seen closed element breathers with dual snorkles that guys have attached flex duct to to pipe in some cold air but was wondering if there was a drop base version of that dual snorkle breather as my factory breather is a holley style drop base for hood clearance.
Old May 10, 2007 | 09:44 AM
Surfer69's Avatar
Surfer69
Old May 10, 2007 | 10:39 AM
Bill Z's Avatar
Bill Z
I was interested in this too. When I did my research, the biggest problem was the hood clearance and the restriction of any adapter fitting on the carb. My 71 has the standard hood. If I used the 1 or 2 snorkel air breather, the steel breather would heat up the air going into the carb.
Last year when I was looking, I just couldn't find anything that would work.
I'd appreciate it if you would share when you find something that would work.
A friend told me that Nitrous is a good way to introduce cold into the inlet air. It is suppose to come out of the nozzle at 30 below.
Old May 10, 2007 | 02:42 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
My 77 had the dual snorkel ,in plastic though.would that work ?The air came from in front of the radiator.
To Drop base air filter / cold air kit.
