Correct paint
Old May 10, 2007 | 01:01 AM
AWilson's Avatar
AWilson
Default Correct paint
Whats the best way to get some of the correct color paint. Do I go down to the local auto body supplier and say I need a quart of Lemans Blue for a 68 Vette? Or do alot of these guys not get it mixed right? For now all I am doing is painting my interior door panels and eventually the floor, etc. Just the things that will get covered up anyway with interior trim parts.
Old May 10, 2007 | 07:52 AM
Tommy Samuels's Avatar
Tommy Samuels
If you go to a quality paint shop they'll have the recipe cards on file and should be able to mix the color "correctly" so that it matches the color card. Just because they mix it to the recipe doesn't mean that it will match your car though. fading on darker colors is a real problem
Some shops will be able to color match to a panel on your car.
Old May 10, 2007 | 08:17 AM
Paul L's Avatar
Paul L
Give them the code for their brand of paint and they will mix it for you.
http://corvettepaintcodes.com/
Old May 10, 2007 | 08:43 AM
sxr6's Avatar
sxr6
That's exactely what I did.
Went to local auto parts & got a quart of LeMans Blue to repaint my tops & hood. Was some worried about the results but unless the light is just right you can't see the shape diff between whatever fadeing has occured & the new stuff
Old May 10, 2007 | 10:33 AM
jackson's Avatar
jackson
MANY MANY years ago I mixed car paint in our area's largest volume auto paint store ... & did a lot of it! Anytime it's older paint ... or ANY metallic ... leave the car or a representative panel-chip at the paint store ... the formula may require adjustment ... there are many existing factors that can affect a good match. Look at birch silver metallic on CURRENT GM pu ... it's a fact GM has several formulae for the very same paint code ... check w/ GM dealer body shop if you don't believe that. The more things change the more they stay the same.
To Correct paint
