C5 Calipers On A C3 ?????
Old May 10, 2007 | 04:32 AM
FUNDERBURK's Avatar
FUNDERBURK
Default C5 Calipers On A C3 ?????
Has anyone put C5 or the red Z06 calipers on their C3. I didn't know if there is a custom made bracket out there somwhere or if someone had fabbed up something................looking for info.
Old May 10, 2007 | 10:02 AM
Corvette Engineering's Avatar
0Corvette Engineering
Former Vendor
It can be done, but it requires the Master Clyinder and front and rear brakes from a C5.
You also have to match the pedal ratio and the booster boost.
Keith
Old May 10, 2007 | 11:06 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
The clamping force of a C5 caliper is much greater compared to a C3 caliper.
Old May 10, 2007 | 11:44 AM
Former Vendor
Don't you mean that the fluid pressure required is higher in the C5 to achieve the same clamping force?
Keith
Old May 10, 2007 | 02:07 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
i attempted this last year but it's a serious undertaking i don't recommend.
first off, a stock c5 rotor will not fit the front spindle correctly. the machined surface on the back is about 1/8" smaller diameter than the factory rotors. either the spindle needs to be turned down or an aftermarket rotor with something like an aluminum hat would need to be used.
second, the front calipers slide so far back being a two piston sliding design, there is major clearance issues when the wheels are turned.
i'm not exactly sure why the rears didn't work but there was engineering involved in that as well.
it may cost twice as much but a wilwood or similar system is going to be far easier to fabricate than the C5 system.
not to bust your bubble.
<EDIT> i now recall that the problem with the back is that maintaining approximately the same mounting location on top of the T/A, the problem is dangerously close interference with the framerails on suspension compression.
Old May 10, 2007 | 02:09 PM
Van Steel's Avatar
Van Steel
Keith
Yep
Old May 10, 2007 | 02:18 PM
Van Steel's Avatar
Van Steel
Keith,
What do you offer with your 6 Piston caliper upgrade?
Old May 10, 2007 | 04:32 PM
redc3's Avatar
redc3
how many pistons does a c5 caliper have? is the power assist that much greater on a c5 than a c3? i think any advantages are from anti lock and super wide tires. sorry, but we have 4 piston calipers on our c3's, and you will pay extra for those even on todays cars!
Old May 10, 2007 | 04:42 PM
68 NJConv 454's Avatar
68 NJConv 454
VBP is in the process of doing a kit for the C5 caliper onto a C3. But like mentioned, you have to upgrade the rotors to something custom to fit the C3 spindle and the MC needs to be upgraded.
For now go with a wilwood kit and take the guess work out of it.
Old May 10, 2007 | 06:23 PM
IronJen's Avatar
IronJen
Abby Normal
Originally Posted by redc3
how many pistons does a c5 caliper have?...
two on the front. i believe one on the back.
Old May 10, 2007 | 08:59 PM
redc3's Avatar
redc3
see! i think the advantage is in rotor size and tire witdh only.
Old May 10, 2007 | 09:22 PM
IronJen's Avatar
IronJen
Abby Normal
actually, the advantage to chevrolet is the reduced production cost and unsprung weight. a fixed four piston will always provide better clamping force than a similarly sized two piston slider.
Old May 10, 2007 | 09:36 PM
FUNDERBURK's Avatar
FUNDERBURK
Alright thanks guys, I got a lot of info here and I think that ill just rebuild the ones I have on th car now.
Old May 10, 2007 | 10:00 PM
redc3's Avatar
redc3
ok.... isnt that the point im trying to make? im saying that the c3's brakes are hard to beat right out of the box even by todays standards. the only advantages are rotor size ( leverage ) and tires ( grip )
Old May 10, 2007 | 10:53 PM
Former Vendor
Originally Posted by Van Steel
Keith,
I don't offer a 6 piston caliper.
No one make one with enough piston area. If I did make a front kit with a smaller master clyinder, I can't find a rear caliper with small enough pistons to keep the brake balance .
Thats why 4 piston calipers are the calipers of choice. I'd be all over a 6 piston if I could find one.
Old May 11, 2007 | 08:21 AM
Vince'82's Avatar
Vince'82
what about the Wilwood GN III calipers ?
they have 6 big pistons (1.75"/1.38"/1.38"). piston area is almost equal to stock front calipers.
Old May 11, 2007 | 08:34 AM
Former Vendor
Oh yea, I forgot about those. Have you priced them?
About $350 each. Also they require 12.19" rotors so you'd have to do a custom rotor.
This something that can be done with VBP aluminum hubs custom rotors from Coleman and my brackets, not cheap though.
Remember, The brackets will accept any caliper that uses the 3.5" mount standard.
This includes some pretty fine calipers from many many manufactures.
Alcon, RedDevil, I think even Brembo.
Also according to Wilwood the Billet Superlight 4 is a better caliper than the GN III.
But it doesn't say 6 piston on the side,
To C5 Calipers On A C3 ?????
Old May 11, 2007 | 08:50 AM
Scooter70's Avatar
Scooter70
70LS1 already did it.
http://temp.corvetteforum.net/c3/70lt1/brakes.shtml
Old May 11, 2007 | 09:39 AM
PatsLs1vette's Avatar
PatsLs1vette
matt beat me to it,jeff 70ls1 has already converted his to c5 setup.
Old May 11, 2007 | 05:25 PM
vetteaddic's Avatar
vetteaddic
Originally Posted by Scooter70
70LS1 already figured out that it takes minor machine work to get the rotors to fit and then just fab up some caliper brackets for something else besides the c-5 calipers,
Thats what I want bigger rotors and better calipers ,yeah we all want that,I just don't feel like spending 3 grand for a brake upgrade.
