transmission 350TH
Old May 10, 2007 | 01:52 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Default transmission 350TH
Im looking to purchase to original style pan that was on my 77 350 auto . it has a chrome pan on it now that leaks all the time..........my question is did they make 2 styles. one with a plug and one without a plug??????... i found one without the plug for 20.00 .. is this ok??
Old May 10, 2007 | 02:49 PM
SIXFOOTER's Avatar
SIXFOOTER
that looks like a pretty good deal. Tranny juice only gets changed every 25k or so and you should do a new filter then anyway so a plug isn't necessarily all that big of a help. What leaks on the one you have? Is the lip warped? What kind of a gasket did you use? Sealer? Correct torq on the bolts?
Old May 10, 2007 | 04:04 PM
ptroxx's Avatar
ptroxx
It leaks at the plug... But like you said you should only have to get to a plug when you change the fluid and if you change the fluid you should do the filter..... So im going to get it and get it ready for my winter projects...the list is getting bigger.....Oh no UPS at the door.. Must be More stuff for the car..
Old May 10, 2007 | 09:14 PM
Roughrider's Avatar
Roughrider
I don't believe GM supplied trans pans with a drain plug...that's aftermarket stuff. Much of the aftermarket stuff is thin guage stamped steel that is "springy" and constantly causes the bolts to back out...the same thing goes for cheaper valve covers.
Get a genuine GM cover or a quality aftermarket trans pan.
Old May 10, 2007 | 11:21 PM
ptroxx's Avatar
ptroxx
I called around and found a pan without a drain plug for 20.00. Im going to get it in the AM. ANd ill just wait till the winter to change it.. Atleast i have it.
Old May 10, 2007 | 11:24 PM
SIXFOOTER's Avatar
SIXFOOTER
If it leaks at the plug, there is supposed to be a gasket, if not, silicone is good to go for $3
To transmission 350TH
