L81 Camshaft selection... What do you think?
Old 08-29-2007, 09:48 AM
  #41
worship79
Support Corvetteforum!
worship79's Avatar
But, one could leave the heads on, right?
Old 08-29-2007, 12:12 PM
  #42
Angel303
Angel303's Avatar
Yes, you can leave the heads on to change the springs. You would need to use compressed air to pressurize the chamber or fill it with nylon rope.
Old 08-29-2007, 12:43 PM
  #43
UKPaul
UKPaul's Avatar
... or do what I did, if possible. Turn the cylinder you're doing to TDC. The piston will stop the valve dropping in & you should be able to change the springs without messing about with rope or compressed air. I was easily able to do mine this way with stock heads, pistons & valves. To be safe, remove the plugs so that you're sure that the piston is at TDC & don't forget to turn the engine to TDC again when you step on to do the next cylinders valves. I used a little clamp (from Summit?) to compress the springs & just used my fingers to pull the valve tip up enough to be able to drop the collets (keepers) in.
Old 04-17-2015, 01:21 PM
  #44
Piper5314
Piper5314's Avatar
I guess I'm going for the Comp268H. I had a 79 with the L82 before and I just loved the way it sounded. Looks like the 268H is the closest to the L82 GM151 accept for the SLA (110 instead of 114). I went through a lot of threads and it seems that the 268H fill fit my application and the computer will work with it. Roller lifter? almost $1000 ! I think I'm just gonna go easy on my first camshaft swap and go for a flat tapped hydraulics lifters and roller tip rocker arms.
Can I get the 1.6 ratio rocker arms with stock valve springs without binding??
Angle.....You keep referring to the GM151 as the L82 cam. This is incorrect! The GM151 cam (GM#3863151) is the cam that originally came in the 350hp/327 engine. Not the L-82.
In days past, I had a 1978 Silver Anniversary with L-82. I replaced the L-82 cam with the GM151 cam which I have always liked. It killed the vetts performance for some reason. Switched it back after 1 week. All was good again.
Just food for thought!
Old 04-19-2015, 09:27 AM
  #45
redwingvette
redwingvette's Avatar
I have the crane 2040 (same as H266) in my 73. Bored over .030, Edelbrock 64cc heads, Holley spreadbore 4175 carb on Edelbrock intake.
Magnaflow exhaust system.
Runs great and I average about 18mpg with the od trans and 3.55 gear.
I was going to change cams but the car runs to good to mess with.
Before I added the exhaust and tuned the carb with an AFR meter a Dynojet chassis dyno put it at 220hp, 277max torque in 3rdgear at the wheels for what its worth.
Old 04-19-2015, 09:52 AM
  #46
wilcar
wilcar's Avatar
I had a 76 L82 with a T400 and replaced the cam with an Isky 264 Mega cam 214-214 .450 lift on a 108 lsa. Lots of low and mid range punch with that cam and a nice throaty idle. Nice cam for a low c r 350.
Old 12-06-2017, 11:42 AM
  #47
jeremylspencer
4th Gear
jeremylspencer's Avatar
Default taking a chance
Just ordered a xe 262 from comp cams new springs seals keepers retainers an double roller timing set included...apart from true dual exhaust my l81 is all stock the computer still functions great car has great power now. Will the 262 cam still work well with stock engine?
Quick Reply: L81 Camshaft selection... What do you think?
