Cruise Control ??
Old May 11, 2007 | 01:15 PM
SIXFOOTER's Avatar
SIXFOOTER
Default Cruise Control ??
Anyone tried to adapt a cruise servo/transducer module from mid to late 80's car to a C3? what would it take to get it working?
I am having trouble locating a transducer for my 81, aparently 2 yr only 81, 82 and they are $$. Ebay peckerwood is trying to rip me off on the one I bought there.
So I was wondering, what would it take...
there a 4 wire connector on the newer unit, and a vac hose. But I don't remember a speedo cable so I am asuming it gets a signal from somewhere, 81 and 82 have a speedo output signal to the ECM, got me thinkin...
Old May 11, 2007 | 01:19 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
80s don't have the ECM. Cruise servo is vacuum. Brackets and all should mount right up in earlier models. Controls are in the turn signal lever.
Old May 11, 2007 | 02:04 PM
MN81C3's Avatar
MN81C3
If I remember right, the only differance between the 79&80 Cruse and the 81-82 is that the 81-82 have the resume feature. I don't think they are controled by the ECM as Bubba dissonnected mine and my cruse works fine. I am getting a little bounce in the Speedo and need to change the Speedo cables. If you don't think you need the resume - look for a 79 - 80 version. Good Luck.
Old May 11, 2007 | 02:15 PM
SIXFOOTER's Avatar
SIXFOOTER
Thanks, I wondered what the diff was.
Old May 11, 2007 | 02:56 PM
palazzopl's Avatar
palazzopl
I just had the same problem finding one for my 81..There are two different models one has a two wire plug and the other has a three wire plug..You can get it from eklers.com or mid america. If you have the resume module on the top take the bracket off and put it on the new one.. Mid America was the cheapest for the two wire $99 part number 609549..
Old May 11, 2007 | 03:06 PM
bluesilver82's Avatar
bluesilver82
I have seen them as cheap as $75.00 Look up American Corvette in Powder Springs GA, They have them remanufactured.
Old May 11, 2007 | 03:31 PM
Kalway's Avatar
Kalway
I got mine from kragen. Works great remanfactured though.
To Cruise Control ??
