I have a completely stock 1977 L48 with a THD350. I am in the process of removing the L48 to make way for a 406.
The rotating assembly for the 406 will be internally balanced and I am not sure if I need a 153 or 168 tooth flexplate. I want to replace the 30 year old flexplate.
If I want to retain a stock style starter which flexplate should I install? I cannot find information that indicates what type of flexplate was stock in a 1977 L48.
I'm not sure which one you need, but I would suggest that you get a flexplate that's SFI approved. They are stronger, welded on both sides, and a little thicker than stock.
It will depend on your engine balance too. Internal balance requires a different flexplate than external. And 153 or 168 will depend on your bellhousing and starter. The 153 used a smaller bell, if I remember, and the nose on the starter to get the gears closer.
If you're getting it internally balanced then all you need is a regular 350 type flexplate. The idea on a stronger one is always a good idea..but depends on what you will be doing with the car.
To tell if you need a 153 or a 168....look at the stock starter. If the two mounting bolts are staggered..it's a 168 (most likely on a '77)..if they are straight across..it's a 153 tooth one.
Aftermarket mini starters often use bolts straight across regardless of flexplate.
