77 car alarm system
Old May 11, 2007 | 09:32 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Default 77 car alarm system
I Was wondering if anyone is still using the car alarm system on there cars now. When i purchased the car i was told it works but sometime the car will not start and you have to disconnect the battery and then it will start again.. anyone heard of this?
Old May 11, 2007 | 11:26 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The factory alarm system on your car will not take out the battery! All it is designed to do is honk the alarm horn!
On 1977 you had early and late design cars. Some with the alarm switch in the fender, some in the door. But both worked the same and only made the alarm horn blow when tripped!
Willcox Inc.
Old May 12, 2007 | 01:55 AM
bruiser's Avatar
bruiser
St. Jude Donor '15
Mine still works and it has starter disable and honks the horn. Its turned on by by the door key lock. You may be accidently turning it on when you unlock your door.
To 77 car alarm system
