Which fan controller
Old May 12, 2007 | 12:08 PM
bruced267's Avatar
bruced267
Default Which fan controller
Im looking at the Delta current coller, I have daul spals which one would you use? FK35, or FK60 I see that 1 controller wil run two fans by installing a splitter. So is it the combined load of two fans for 6o amps? or will the 35 amp unit take care of the job? I know a few members have installed this controller what do you think? Or is there some thing better?
Old May 13, 2007 | 01:36 PM
bruced267's Avatar
bruced267
TTT
Anyone? I know a few of you guys have intalled them. I would think its combined load of both fans. But I want to be sure before I go and order one
Old May 13, 2007 | 02:02 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Do a search for a member called baskin1 I think, he is the person that designed them and he also makes them. There was a thread about them a while back on which one to use.
Neal
Last edited by chevymans 77; May 13, 2007 at 02:14 PM. Reason: correct member name to baskin1
Old May 13, 2007 | 02:41 PM
bruced267's Avatar
bruced267
Yeah I read the post, doesnt really mention what was used, He also had a Single ford fan I forgot wich one.
http ://forums.corvetteforum.com/showthread.php?t=1608890&highlight=Elect ric+fan+wiring
Old May 13, 2007 | 02:43 PM
bruced267's Avatar
bruced267
That didnt work to well??
Old May 13, 2007 | 03:13 PM
miechesa's Avatar
miechesa
I'm using the FK60 with my dual spals. Works great. I figured since I used a 30 amp fuse for each fan with the original spal controller, A 60 amp Delta controller would be fine for both.
Old May 13, 2007 | 04:08 PM
bozzman3's Avatar
bozzman3
I used the smaller set up.When the fans come on with this controller they don't come on at full power.Thats when there is the highest electrical draw.These fans do not pull 30 amps each even on high!
Old May 13, 2007 | 06:22 PM
bruced267's Avatar
bruced267
How easy is the install? From what I see it looks pretty straight foward I already have wires run from the battery for two relays that are controlled by a Coolant temp switch. Where did you mount the controler with the daul spals?
Old May 13, 2007 | 08:11 PM
bozzman3's Avatar
bozzman3
Its a straight forward install.No relays are needed.You need power and ground wires.The Dc controller does like power directly from the battery.A coolant temp sensor is supplied with the controller and must be used to have the variable feature,it mounts in the Rad fins.I mounted the controller on the left side of the firewall
To Which fan controller
