I bought this puller thing to get my stock damper off. My question is what do you guys use to get the new one back on? I have a threaded crank and I thought about using a grade 8 bolt to reinstall.
I just want to not tear up the crank snout threads because it got tight really quick and I did not want to crank on it with a 1/2 drive.
Be careful..the size issue is a real one with ATI's. Excellent part that is designed undersized so you can select fit it to YOUR crank. It will likely need to be honed.
