where is the igntion switch
Old May 12, 2007 | 08:49 PM
hotshot79's Avatar
hotshot79
Default where is the igntion switch
1979 where is the ignition switch, on/below the steering column? what does it look like?
Old May 12, 2007 | 09:43 PM
Duke94's Avatar
Duke94
Yes, it's under the dash on the top of the steering column just forward of the dash mounting flange (the slotted hole to the right in the picture). The rod connects to the ignition lock. Looks like this:
...Roger...'s Avatar
...Roger...
Its on top of the column-its about 4 inches long
Old May 13, 2007 | 01:14 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Originally Posted by Duke94
Yes, it's under the dash on the top of the steering column just forward of the dash mounting flange (the slotted hole to the right in the picture). The rod connects to the ignition lock...
And a PITA to change...
Old May 13, 2007 | 12:27 PM
TimAT's Avatar
TimAT
But the UNDERSTATEMENT of the week!
Old May 13, 2007 | 11:08 PM
hotshot79's Avatar
hotshot79
thank god it was not the ignition switch, the 4 wire connector was the problem, able to move it around and when I heard the power antenna going down the rest of the way I was a happy guy. A new connector is in my future but at least I got it started and back in the garage. Thanks to all for your great input.
To where is the igntion switch
