Roller rockers.....
Old May 12, 2007 | 11:48 PM
toolman0114's Avatar
toolman0114
Default Roller rockers.....
I am going to change my stock rockers to 1.6:1 full roller aluminum rockers. Do I need to change the length of my push rods? if so, what size do I need to use?
Old May 13, 2007 | 12:53 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
You'll need to answer that one yourself by verifying proper geometry when installing your new rocker arms.
Basically, you want the roller tip to roll from the intake side of the valve tip, across the center of the tip (at approx. mid-lift), to the exhaust side of the valve tip (at full-lift) and back. If the pushrods you have don't provide that, you'll need new ones.
Don't mean to sound like a CompCams rep here (just quite familiar with their stuff), but the Hi-Tech Checking Pushrods they sell are the coolest tool for measuring required pushrod lengths I've ever seen.
Hope you're existing pieces work out for you...
