wth is that sound!?
Old Oct 21, 2001 | 03:14 PM
C3sharkattack's Avatar
C3sharkattack
Default wth is that sound!?
Ok, yesterday I was cruising around in my 80 Vette and this buzzing sound started coming from the rear of the car and it started doing this every 30 minutes and would shut off about a minute later. Is this my alarm going off or what?
Old Oct 21, 2001 | 03:40 PM
C3sharkattack
Default Re: wth is that sound!? (C3sharkattack)
ttt
Old Oct 21, 2001 | 03:58 PM
73Ken73's Avatar
73Ken73
Could it be your power antenna
Old Oct 21, 2001 | 03:59 PM
C3sharkattack
Default Re: wth is that sound!? (73Ken73)
Nope, mine doesn't have a power antenna.
Old Oct 21, 2001 | 05:02 PM
C3sharkattack
Come on guys, someone has to know.
Old Oct 21, 2001 | 05:28 PM
KenSny's Avatar
KenSny
Is this a trick question, cause you sure did not give us much to go on. Sounds like the problems my wife comes up with "there's a noise and it goes rattle-rattle every now and then - but only once a month or so....". Maybe your's was a bee in it's dying throes....
Old Oct 21, 2001 | 08:55 PM
Chuck Harmon's Avatar
Chuck Harmon
Default Re: wth is that sound!? (KenSny)
Your car has a closed loop fuel system for evaporation. Is there a pressure relief or one way pressure valve near the tank that could buzz when the either the tank gets hot and expands, or when it has to pull air in to replace the volume of gas consumed? You might try driving with the gas cap loose to see if it makes any difference. It might even be the cap seal. Just a thought.
Chuck
[Modified by Chuck Harmon, 4:59 PM 10/21/2001]
Old Oct 21, 2001 | 09:07 PM
Stingy74's Avatar
Stingy74
Default Re: wth is that sound!? (Chuck Harmon)
I like Chucks idea. I always hear this very slight buzz when I get into my garage shut the car off and close the big door. When I take the fuel cap off it goes away. No lies, this happens every time I put the car away after it's been out cruising for awhile. Until I read this thread I had no clue what it could have been caused by.
To wth is that sound!?
