1968 wiper door adjustment
Old May 14, 2007 | 01:25 PM
dave finamore's Avatar
dave finamore
1st Gear
Default 1968 wiper door adjustment
one side of my wiper door (drivers side only) has a nasty vibration when closed while the engine is running- is there any adjustment i can make to eliminate this?
Old May 14, 2007 | 02:33 PM
theandies's Avatar
theandies
Open the door with the override switch under the dash and there are some phillips screws with a jambnut on them. These are the down stops. Just make sure that when adjusting the door you don't mess up the motor cutout switch that prevents the wiper motor from moving the blades before the door is in a safe position. I'll take a picture if you can't find them.
