Removing outer bearing races from Spindle Support
Old May 14, 2007 | 05:32 PM
NuclearBob's Avatar
NuclearBob
Default Removing outer bearing races from Spindle Support
Is there a best (without using a hydraulic press) way to remove the outer races from the spindle support piece?
Old May 14, 2007 | 05:39 PM
Vette Gator's Avatar
Vette Gator
There are slots on either side of the spindle support that allow you to drive the races out with a punch and hammer. I had to clean a bunch of old grease out of my carrier before I found the slots, but they are at 9 and 3 o'clock if I remember correctly.
Old May 14, 2007 | 06:48 PM
1981 corvette's Avatar
1981 corvette
Good memory, the slots are at 9 and 3 o'clock; I just removed my races 10min....ago; with a drift and hammer.
Old May 14, 2007 | 07:30 PM
NuclearBob's Avatar
NuclearBob
I see them... Thanks!!!
To Removing outer bearing races from Spindle Support
