#s help
Old Oct 21, 2001 | 06:32 PM
ridged84's Avatar
ridged84
Default #s help
Can someone clue me in on a little number translation
eng block front pass side#VO806CKX
drivers side rear (by the fire wall) #3970010
Q-jet #7042203DK :crazy:
Old Oct 21, 2001 | 07:09 PM
78Vette-SA's Avatar
78Vette-SA
Default Re: #s help (ridged84)
V: Flint Engine Plant
0806: August 6th
CKX: 350, 200hp, 8.5:1 compression, 4 barrel, Automatic
The Casting Number 3970010 also matches.
The black book states the Carb is a Rochester Qjet off the same engine but Manual Transmission. ?
I would check the number probably right below the V0806CKX and the last 6 should match your VIN's last 6.
Old Oct 21, 2001 | 08:09 PM
ridged84's Avatar
ridged84
Default Re: #s help (78Vette-SA)
thanks joe the #s next to the vo# match the vin. I guess someone changed the carb though.My car is a auto.
To #s help
