Spark Plug wires?
Old May 16, 2007 | 06:59 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default Spark Plug wires?
Hey all, I'm in the market for some new plug wires. I was wondering if anyone has done any testing on different wires? I've been using the MSD 8.5mm Super Conductors and they worked well. I do have an MSD ignition box and I seem to recall them stating not to use solid core wires with it.
So what's the recommendations? TIA
Old May 16, 2007 | 07:36 AM
Durango_Boy's Avatar
Durango_Boy
Email this guy. He's got the perfect wires for you. Taylor Spiral Core wires. They come long so you can cut them to your own custom length and you terminate them yourself for a trick fir. He has varying thicknesses, 8.5 up to 10.5, and in varying colors. He's a cool guy to work with. Tell him Matt sent you.
wtextremeblaze@yahoo.com
Taylor is one of my favorites.
Old May 16, 2007 | 09:11 PM
chris75stingray's Avatar
chris75stingray
i've had my 8.5 msd set for a year with no problems. i also have fiberglass shields over the boots to keep them from burning /cracking
Old May 16, 2007 | 09:19 PM
TimAT's Avatar
TimAT
The reason for NOT using solid core wires with an MSD box-- RFI-- rdio frequency interference. the wires will affect the signal(s) that control the firing of the box. Same thing with your radio, it will make so much noise with solid wires you won't be able to hear any music.
Old May 16, 2007 | 11:51 PM
gkull's Avatar
gkull
Mike - The only wire for a real car like yours are the Taylor 409 race wires.
I'm tonight down on the hot Vettes. I am going back to to 125 shifter Karts. I almost lost my vette racing and decided to get a dedicated race machine.
Old May 17, 2007 | 07:33 AM
Durango_Boy
Aren't those the 10.5" wires? I would have bought some as I found a set new for $65 but I would have to replace the looms and I could get a set of the 8.5" Taylor Spiral Core for half that.
Old May 19, 2007 | 08:40 PM
SmokedTires
St. Jude Donor '05
Thanks everyone. I will check out the Taylors Not too worried about radio noise, I have the delete option on that one
Old May 20, 2007 | 01:27 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
i went with the taylor thundervolt 50's check them out also.
Old May 20, 2007 | 01:59 AM
SEVNT6's Avatar
SEVNT6
How about 8.5mm wires and using all of the factory shielding? I want to keep the block shields along with the rest but I've been wondering if that extra .5mm is enough to make for some tight spots....
To Spark Plug wires?
